Question about Oppo Digital BDP-83 Blu-Ray Player
Hello, I connected a new oppo BD83SE via the
Hello, I connected a new oppo BDP83SE via the analog out‘s to the analog in‘s of my AV receiver, an audiosignal I can get only from the FL and the FR jack (if connecting the FL or FR out of the BDP to the other in‘s of the amplifier I get an audio signal), it means, that the effect outputs of the BDP don‘t work or I must change something ?
B&k avr 7 with SACD inputs needs independent tone equalization settings
For your stereo configuration, refer to the preamp they are connected to for tone controls.
For your center and surround channels, refer to the B&K setup menus for those controls.
Feb 04, 2012 | Denon Audio Players & Recorders
I just purchased a Yamaha RX-V465 AV Receiver, and I cannot get any sound out of it except for when I have Tuner selected. I have my OPPO CD/DVD player hooked up via HDMI and via the stereo analog audio...
Also the test tone is working OK (Setup / Speaker Setup / Test Tone)? Have you used automatic speaker setup with the supplied YPAO microphone?
For HDMI, you need to configure the receiver to "take" out the audio from HDMI. Go to Setup / Function Setup / HDMI / Audio and select "Amp" to route the audio to receiver, or "Amp+TV" for audio to go both to receiver and to TV. You can also check in Options Menu / Signal Info that receiver has recongnized the sound and what format it thinks it is in.
Jan 09, 2011 | Yamaha Rx-v465/rxv465 Home Theater...
Can I connect component av cables "in" to my Yamaha RX-V365 and connect "out" to my TV and get both audio and video?
Receiver does support 3x component inputs and one component output. Both these can carry only video signal, not audio. So you have to connect audio separately, either stereo via analog 2x RCA connectors and digital SPDIC via optical (2x) or coaxial (1x) cable.
Feb 23, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Marantz SR4003
Hip shot: No one let's you record digital audio onto analog equipment (yet).
On looking at Page 26 of the manual, that is verified. (See the Notes). Use only the analog audio and it will probably work for you. The A/D switch decides which you will use.
Jan 28, 2010 | Marantz SR4003 Receiver
How do i assign audio from optical AV to hdmi4?
Hi, unfortunately this is not possible on RX-V465. HDMI can have sound only from HDMI. All A/V inputs are paired, except for analog Audio 1-2, to which you can assign any of the analog video AV1-6.
But you can connect the video via HDMI directly to your TV and connect only audio to receiver via optical AV1 or AV4.
Nov 17, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Is possible to receive TV frequency with VCR hokeed on TV via AV
Yes but i am sure that does not have a digital tuner in these day and ages your going to need one. But it has a analog tuner and it is possiable.
Thanks and do rate.
Aug 18, 2009 | LG V271 DVD Player/VCR
Receiving tv analog audio.
Based on the description provided, you seem to be on the right track.
Be sure to select the appropriate "source" on the receiver using the remote (or front panel). The AV connection on the back of the receiver is typically labeled (i.e. Video 1, AUX, VCR... or similar). If there's only one unlabeled input, choose something that looks like "AUX IN" from the menu.
Also, make sure that you connected the cables to the TV via the "Audio Out", not the "Audio In" ports.
If these are too obvious and you have already done this, please provide additional information.
May 14, 2008 | Onkyo HT-SR800 System
Sony DVP-NS77H No outout
I had the same problem unitl I read the manual a little more carefully.
I found that ALL connections through my AV receiver had to be identical. I was using component connections with analog connections.
Since I switched to all HDMI connections (cable box to AV receiver, DVD to AV receiver and AV receiver to TV) all is fine.
Hope this helps.
Mar 16, 2008 | Televison & Video
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
Oppo Digital BDP-83 Blu-Ray Player Logo
118 people viewed this question
Top Oppo Digital Televison & Video Experts
jasbo
jasbo
Demonic-2011
Demonic-2011
LP
Are you an Oppo Digital Televison and Video Expert? Answer questions, earn points and help others
