Question about Bosch HMB402 Microwave Oven
I have a Bosch HMB405 microwave, 4 years old. It is making a loud humming noise and not heating. Magnetron? Is this something I can fix? Is it worth it? Paid $400+.
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
NOTE_ This will, generally, require the skilled hands of a service tech. The magnetron is a very dangerous device, that can cause injury if not handled correctly. Due to the fact that the magnetron is emitting the noise, this will indicate that the fuse is ok. The magnetron for this particular unit will cost $138.60. Factor in the service call fee, and the repair will be around the 300 dollar amount.
Posted on Dec 11, 2009
  • 126 Answers
If it is the magnetron you should be covered in warranty by Bosch.more likely problem is bad capacitor and diode ~ $45-50 parts $80 labor +service charge where applicable.Hope this helps. Please rate my response :)
Makes loud hum noise but does heat
That is a symptom that the magnetron circuit has failed. It the part that generates the microwaves that heat the food. Not worth fixing since the replacement part can cost as much as as a new oven. Sorry.
May 24, 2011 | Whirlpool GH8155XJ Microwave Oven
My Kenmore 721.626222 which I have had about 6 years, runs but does not heat. There is also a strange smell - something like a burning smell.
When the oven does not heat, the problem is usually due to the magnetron failing. It the part that generates the microwaves that heat the food. It fails by shorting out causing a loud buzzing noise. The burning smell is the being magnetron overloaded due to the short. It not worth fixing since the replacement cost of a magnetron is close to the price of a new oven. Sorry.
Feb 09, 2011 | Kenmore 62622 Microwave Oven
The microwave makes a loud "hum or buzz" noise but will not heat up the food My microwave is running and sounds like it is working but will not heat up anything.
Hi, Your hi-voltage system has gone bad. The noise you are hearing is the hi-voltage transformer. This has taken the magnetron which does the heating out. The magnetron has a 5 year warranty on it, the rest of these parts only have a year on them. Contact your nearest repair center. Thanks,
Jan 17, 2011 | Microwave Ovens
My microwave is making a humming noise but not heating. replaced, capacitor, diode, checked all switches including thermal switches and the wires look good going to the transformer and magnitron. Please...
The part that you did not replace is the problem with the oven, the magnetron. It typically fails and shorts out, causing the oven to make a loud humming noise. Not worth fixing since the cost of the magnetron is typically as much as a new oven. Sorry that you spent your time an money replacing the wrong parts.
Jul 14, 2010 | GE JVM1440 Microwave Oven
Microwave comes on but not heat item
It's most likely the magnetron that has failed if it does not heat the food. The magnetron is the part the generates the microwaves. When it fails, it typically shorts out, and makes a loud hum or buzzing noise. If this is the case, it is not worth fixing since the cost of the magnetron is almost as much as getting a new oven. Sorry.
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
Whirlpool builtin microwave humkming loudly
yes for sure magnetron or diode has gone bad.but usually it is the mag.magnetron when go bad they start making noise and stop heating.when chaging magnetron chg the diode with it.
Aug 18, 2009 | Whirlpool MH7140XF Microwave Oven
My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Mar 20, 2009 | Frigidaire FMT148GP Microwave Oven
Makes loud hum and faint smell when turned on
It sounds like your magnetron failing.
If a fuse were blown, it would be totally dead with no lights, no display, etc.
Keeping it out of the landfill a while longer by getting it fixed is always an option.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Nov 20, 2008 | Goldstar MV-1501 Microwave Oven
Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Sep 24, 2007 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Bosch HMB402 Microwave Oven Logo
194 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
