Question about Syntax OLEVIA LT20HV 20 in. LCD Television
I need a set of sams for a olevia LT20s can you help me
The olevia lt20s does not start. once you press the start button the red pilot light disapear bu after a few seconds comback
Posted on Mar 21, 2010
WHAT IS MODEL# FOR REMOTE CONTROL FOR OLEVIA TV MODEL LT26HVE?
Here you go https://www.ebay.com/itm/OLEVIA-LCD-TV-GENUINE-Remote-Control-LT20S-LT26HVE-LT26HVX-LT27HVS-LT27HVX-/222666328066?hash=item33d7f28802:g:EN0AAOSwmoxZq26G
Oct 20, 2017 | Olevia Televison & Video
How to do a complete initial setup on olevia 542-b11
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Dec 22, 2015 | Olevia Televison & Video
Olevia LT20s
Check power outlet. Connect TV to a different power outlet. Switch off TV manually, switch off power input, remove plug and cool it off for 48 hours and retry. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Televison & Video
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
Apr 18, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Have an olevia lt20s. put it in pc mode and it shut off and wont come back on at all
Try by unpluggin the power cord from the power outlet for about 5 minutes and retr.
Also try with a different power outlet.
Aug 12, 2010 | Televison & Video
I need an Olieva repair manual for a 23 in" TV Flat screen. Model #LT23 HVX. Does anyone know how I can obtain one? Tks.
With the huge number of makes and models, there is no more single source such as 'Sams Fotofax' and mfr's generally will not supply detailed schematics and test info unless to an authorized service center. Olevia is defunct; bankrupt, just like numerous other consumer electronics firms.
If you furnish a description of the failure, you may get some support from our crowd.
If you know the location of the failure (to a board at least) you may get one here:
Jimmy's parts
Jul 07, 2010 | Olevia LT27HVX 27 in. LCD Television
Schematics
Don't think you'll have much luck. Olevia doesn't exist and even when they did it was virtually impossible to find parts let alone service literature. You could try Sams Photofact https://www.samswebsite.com/
but I would hold my breath. Hate to be the bearer of bad news, but Olevia was bad news.
Apr 21, 2010 | Olevia 237T 37 in. LCD TV
No power all of a sudden.
Most likely your power cable not working. check the cords for bare wiring (if any metal is hanging out of the rubber insulator). If it is bare then go and get another cord. That should work.
Jan 29, 2009 | Olevia Televison & Video
Channel Scan
If you have not discarded your old conventional TV or can borrow one, I would connect it to the same signal source you are using with the Olevia. If you get reception with the substitute set, then the Olevia is defective. If you live in a metropolitan area, you could also try sticking a piece of copper wire into the input of the Olevia and selecting antenna input as the source from inside the Olevia's setup menu. If you still get no signal indications (quality is not important for this), then the Olevia is defective.
I'm disappointed to see you having trouble with this set as we own one too. Also disturbing is Olevia's current state; they are in bankruptcy so I would start complaining soon and loudly if you have satisfactorily   identified the Olevia as the problem.
Nov 24, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia t.v.
try rca, lg, philips, yamaha these are compatible with olevia
Aug 28, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Syntax OLEVIA LT20HV 20 in. LCD Television Logo
266 people viewed this question
Top Syntax Televison & Video Experts
Jaime Hernandez
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
