Question about Whirlpool LSN1000LW Top Load Washer
Trying to replace the agits and I cannot seperate the coupler from the agitator. There seem to be four tabs keeping it in place.
  • 999 Answers
Set the agitator on the floor and place a foot on either side of it to hold it down. Grab the top portion and pull up sharply. If you do not have the hand strength or it resists, use a strap or belt tu gain leverage.
Eric
Posted on Dec 11, 2009
Testimonial: "Thanks, that really helpedI I was afraid I'd break the tabs if I pulled too hard, only one broke. Otherwise this was an easy fix."
GE washer model # WHDRR418E4WW : Having trouble removing the plastic cap under the fabric softener dispenser, so I can access the agitator bolt.. There appears to be no simple way to remove it. There are...
that's right just put your fingers under agitator and pull up,under the agitator is a coupler that has a screw in it,whirlpool has the nut in there,if you have a problem with the agitator not moving the clothes around that coupler wears out and has to be replaced.
Oct 07, 2017 | Washing Machines
I have a Whirlpool washer... model number # LSQ8243HQO The top part of the agitator is loose. The bottom part is strong. I think I need what they call dog ear replacements. Can you help me?
yes sounds like the dogs to me.
to replace them,remove the cap at the top off of the top of agitator by pulling it up (no tools required) then remove the clear plastic cover by pulling on one of the two tabs in it,remove the bolts using 7/16" socket and pull the agotator out of the machine by gripping it at the bottem.seperate the upper portion of agitator by pulling it upand the dogs will be located under the clear plastic,to replace them seperate the top barrel of agitator a cam that holds all (4) dogs will come out remove the retainer over the dogs install new ones and reassamble in the line up upper barrel and main agitator you will (2) tabs on main agi. and (2) corosponding slots on barrel line them up and snap in place
Jul 14, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
The bolt has come free from the shaft and is inside the agitator. I have the agitator off and the cap to it off. It is solid under the cap. how do I seperate the two halves of the agitator to retrieve the...
You will need to hook something in the hole the bolt was in and pull real hard. the agitator coupler is still in the agitatorif you notice there are plastic fingers around the coupler and you can pry those back a little to aid in your getting the coupler out.
Jan 22, 2011 | GE WCCB1030 Top Load Washer
Haier xqbm22-c does not agitate
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Dec 25, 2009 | Haier XQBM22-C Top Load Washer
Agitator moves freely, but is not engaged in wash cycle
AGITATOR REMOVAL GUIDE
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytag's may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Dec 11, 2009 | Whirlpool Washing Machines
GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Sep 01, 2009 | GE WJSR2080V
Agitator spins in one direction
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of the upper agitator and that forces the clothes into a downward movement to the bottom of the tub. These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place.
Dec 22, 2008 | Kenmore 22422 Top Load Washer
AGITATOR
You are missing the coupling that holds the agitator to the shaft.
Aug 24, 2008 | Amana NAV5800A Top Load Washer
Top Agitator is not moving
This washer has a set of cheap plastic dogs that grab the inside wall of the upper agitator to move the clothes downward and help them get a better cleaning. The older style These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place. The newer style you simply pop the cover of the agitator and use a 3/4 drive extention to unscrew the upper agitator. replace the dogs and put the top back on. Nothing could be easier.
Jul 30, 2008 | Estate TAWS800JQ Top Load Washer
Whirlpool LSN1000LW Top Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal De
