No sound from monitor
Can't get sound coming from my monitor speakers?? it only comes out of the stand speakers which are not part of the computer? thanks claire
  • scumdee Jan 20, 2008
    None on mute and monitor up full
  • 91 Answers
Check settings on the actual monitor or right bottom corner of your screen double click on a little speaker and check its not on mute or set down.
Posted on Jan 20, 2008
SOURCE:
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
No sound coming from my monitor, what's the problem?
The problem may stem from not having the monitor's speaker system if it has one, hooked up to the output of the sound card on the computer.
Also, if it has an adjustment for volume, make sure it's not turned down to zero volume, and also make sure it isn't set on mute, if it has such a setting.
Most monitors do not have sound on them and many computers require external computer speakers in lieu of sound coming out of a monitor.
Jul 03, 2010 | Hannspree HW191D LCD Monitor
Speaker is not working properly , rattling noise coming
Can you hear any rattling inside if you shake the monitor? It can be blown speakers or they are being driven too hard, just want to make sure before taking it apart. Do not expect too much sound from monitor bulit-in speakers since they use very small speakers that sound like tin can for most application.
Apr 16, 2010 | HP w17e Monitor
Speaker connection for LG W2053TX monitor
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Dec 12, 2009 | Computers & Internet
Scratching clicking noise coming from speakers
maybe you bumped a wire going from computer to speakers.
Are you using the speakers built in the samsung?
try another pair of speakers that are connected to the monitor.
Oct 10, 2009 | Computers & Internet
No sound on monitor
First off is your monitor has any speakers on it or capable off producing any sound? Not all monitors comes with speakers attached to it.
Jul 03, 2009 | ViewSonic Monitor Lcd 22in Wide Va2216w...
No sound from inbuilt speakers
this may be a second post since it appears that fixya didn't take the first one:
you should have a speaker cable in addtion to the monitor cable (big thick cable) coming from the monitor. the speaker cable (much thinner with similar plug as free standing speakers) needs to be plugged into the sound output jack on the back of your computer (jack is possibly colored green).
Mar 30, 2009 | Computers & Internet
Can't get sound through speakers/headphones
You need to connect the speaker wire coming from the monitor to your PS3 if you want the sound to come out of the monitor speaker. Normally, you need an adapter for this.
Mar 15, 2009 | Computers & Internet
Volume
sound does not come from the monitor it comes from the computer. try hooking your speakers up there
Nov 19, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
No sound coming from new hp monitor through windows vista
Alright, I got the answer for ya, first, go into your control panel. Click on Sounds and Audio Devices. Listed in this window should be the name of your sound card. Under that, should be Device Volume, and at the bottom, should be the Speaker Settings, click into Advanced, next to speaker volume. It should show you a diagram of a monitor with the amount of speakers it has selected shown next to it. Where it says Speaker Setup, click and then scroll down until you see 3 settings labeled Monitor Stereo, Monitor Stand Stereo, and Monitor Mounted Stereo. Whatever one enables the sound will be the one you want to stick with.
Feb 25, 2008 | Gateway Essential 500 PC Desktop
Computers & Internet Logo
61 people viewed this question
Ekse
Alun Cox
