Question about Motorola Mobility SLVR L7 Cellular Phone
My phone's screen keeps turning black and then it will come back to color and say I have no signal then it will go back to normal, but every like 2 minutes it will keep repeating this. I took my battery out and the little white thingy is red. I haven't even had it near to water! Help me!
  • jaredf Jan 22, 2008
    i turn on my phone .. it freezes for about 1 min then unfrezes then works for about 7 seconds then repeats the cycle.
That is a software problem, take it to Motorola to get it repaired in warranty.
Posted on Feb 07, 2008
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
Oct 05, 2008 | Nokia N73 Cellular Phone
A while ago my phone started blurring and it started happening more often everyday. all the functions still work. the screen would just mess up and sometimes it would be a little slow. then it started...
hello there ..problem with your display IC i believe its a very old phone
you need to consult a local repair shop...they will probably say that screen needs to be changed but i would advice buying a new phone is always better than repairing ..some other problem will keep on emerging if you go for repairing....while you can buy a new phone that will save a lot of time ,money and energy
hope this help
Cheers
Aug 06, 2008 | Audiovox Cell Phones
Color problem
There are three Cathod Ray guns responsible for the millions of colors.All colors are produced by mixing the three basic colors namely Red Green and Blue (RGB) at suitable proportion. If any one of the three guns fail firing then we get improper colors. This can be rectified by
(1) hitting the monitor at the back by keeping it on a pillow the screen facing down - it will reolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contaction.
(2) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed)
TRY YOUR LUCK
ProfSweetlin
danielswweetlin@gmail.com
Jul 15, 2008 | Samtron 76df 17" CRT Monitor
My phone
well your phone is beyond fixing you just need to go and get a new phone
Apr 28, 2008 | Cell Phones
Tp5560h
Well let see if we can talk you thu "grayscaling " a set, first remove the speaker grill and the front cover to expose the screen/focus controls these will be six controls mounted on a plastic looking box, next turn the set on and get a good signal, Then from the custmer menu simpley go the the pix settings and turn the color all the way down, next use the screen controls to make the pix the best black and white you can. Next turn to a input that has no signal and the pix should be black, if there are small retrace lines simply turn down that color till it goes away , then back to a signal source that should still have a good black and white pix. Put everything back together and turn the color back up
Feb 07, 2008 | Toshiba TP55H60 55" Rear Projection...
Can't get normal color in video mode.
We just solved this problem! Rotate the wheel button (above the Display & Menu buttons) to see the various option (Color Accent, Color Swap, Compact, etc.) and stop when you get to Standard.
Sep 12, 2007 | Canon PowerShot A540 Digital Camera
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
