Question about Maytag MSD2656G Side by Side Refrigerator
Freezer door pops open water supply line needs to be disconnected how do you do break the line.
  • 50 Answers
Pull front vent cover off from under door's and look under refrigerator.There is what is called a quick disconect fitting.The water line is pushed into it.Take hold of the fitting and push on it while pulling the water line out.
Posted on Dec 12, 2009
Inside filter water dispenser suddenly stopped working. New filter removed and no working with or without filter . Water line is fine. Ice maker works.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Mar 18, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
The water dispenser wont dispense water. Line is open and on. I
Dec 23, 2010 | Whirlpool ET1FTTXK Top Freezer...
I have replaced the water filter inside the unit but not it will not despence water.
It is very common on these units for the water line to freeze inside the freezer door. They did not insulate the door well enough. there was actually a recall on many models where they actually replaced the entire door under warranty. To determine this you need to remove the bottom kick panel and there will be a quick disconnect at the bottom of the freezer door. (to remove you need to kind of push the line in and then pull back out) Once this is disconnected close the freezer door and try to call for water. If you get water coming through the line to this point then you know its frozen inside the door. The only fix for this is to shut the unit down for 24 hrs with the door open to let the line thaw back out. If you dont have water to this point you will need to look at your saddle valve where the water line is tapped into your main line. It may be clogged up with calcium deposits. If you have an icemaker and its making full sized cubes this will most likely mean the issue is not with your water supply. Also if your dispenser has a little switch that slides back and forth to go from crushed/cubed/water it is common for these switches to go bad. Hope this helps let me know what you find.
_MJ_
Dec 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Removing the doors from samsung refrigerater RFG297AA
I'm in the same boat. I'm sitting here withe freezer door unscrewed and I have no idea how to disconnect the water line going up the side of the freezer door. I guess I'm going to rip it. I was going to give this hunk of **** to goodwill since the freezer still somewhat worked but now this, screw it.
David
Feb 20, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
The water from the door of my GE Profile fridge doesnt work consistently. Sometimes it does and sometimes is does not provide water. It has started dripping inside the freezer leaving icicles.What to do???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water in door is not coming out very much intermiient
There is a mesh screen filter in the water supply line where it connects to the water inlet valve on the back of the unit. You can disconnect the line coming out of the valve and try the dispenser to see if it comes out normal. You can disconnect it at the bottom of the freezer door to see if it comes out normal there. If it does the water could be freezing in the door. Leave the door open till it thaws out. Cover the freezer with a blanket to prevent loosing too much cold air.
If you have a water filter it could need changing.
Nov 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Low water pressure from water dispenser
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. There is a screen filter in the line where the water supply connects to the water inlet valve.
Oct 14, 2009 | Kenmore Refrigerators
The water in the door suddenly stopped working. We replaced the filter. Water is still flowing because the ice continues to refill. The lock is not on. Troubleshooting section says water line could be...
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 05, 2009 | GE GSH22JFT Side by Side Refrigerator
Water not dispensing from door but still getting ice
Sep 16, 2009 | Samsung RS2534 Side by Side Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
94 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
