Question about Refrigerators
What gauge wire is used in a kenmore 110 volt portable dryer?
  • 478 Answers
12 gauge wire is used depending on what part of the dryer but 12 is standard
Posted on Dec 11, 2009
How do I fix my dryer?
I suspect ur terminal block has a problem
Apr 12, 2015 | Kenmore 62602 Electric Dryer
Wire connections for 220v
110 +110=200 volts red and black wires equal 200 volts
Jan 24, 2014 | Kenmore Dryers
Kenmore dryer does not heat
Find a volt-ohm meter you can use.
Unplug the dryer and test the socket on the wall or on the floor for current. If If you have a 3 pronged socket, the two slanted slots should have 110 volts each, and the "L'' shaped slot is your ground.
If you have a 4 pronged socket, the two straight slots are 110 volts each, and the "L" shaped and the round slots are grounded.
If you do not have 110 volts showing on both slots, you likely have a blown circuit-breaker to reset at your fuse box.
Depending on the year of the dryer, you have the following things to check inside the back of your dryer.
Wiring, for burnt or broken wires, the heating element for a broken wire, and 2,3,4, or 5 thermostats.
Unplug your dryer and remove the back so you can see all the wires and the above parts.
One at a time, remove the wires from each thermostat and see if the thermostst is blown.
You can tell by setting the volt-ohm meter to ohm's resistance, that's the "Infinity" sign.
Check the heating element the same way.
If the thermostat and heating element are good, the needle will go up on the meter. If one is bad, the needle on the meter will remain motionless.
Each of the thermostats and the heating element are removeable, and replaceable.
Be blessed.
Jan 24, 2013 | Dryers
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
Need to hook 230 volts to car lift
this is 2 ---110 volt power feed lines & a neutral ( ground ) 3 wires all together , a second redundent ground won't hurt -----the same power feed as a stove or dryer .make sure to use at least 10 -- 8 gauge stranded wire / check the product requirements ---thicker wire ( smaller gauge number ) for more amprage or loner distance...will also need two 15--30 amp circuit breakers///// check specs......
May 26, 2011 | Air Tools & Compressors
Is kenmore 98702 220?? or 110???
if it has a small 3 prong plug then it's 110v for the washer but the dryer should be factory 220 volt however many were sold wired too! 110 volt! just look at the plug small plug 110v large 3 prong! 220v
Jan 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
I just moved. my dryer didnot dry very well at the
If it is a portable dryer, then the vent hose must be exhausted to the outside. 110 volt dryers don't have much capacity since the circuit can only safely handle up to 1500 watts.
If it is not a portable dryer, please consider other experts' solutions.
Sep 22, 2009 | Kenmore Dryers
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
110 volt/amp dryer
yes ,i see some on line at living direct.its an Haier,they call it a portable.it was about 300$ and that included shipping.if you can't find .i googled 110 volt dryer and their was the link too [living direct] have fun,God bless,tom
Jan 23, 2009 | Kenmore Elite HE4 Electric Dryer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
