Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
Wont power up at all but have second drive and it`s ok also when i use 2nd power to 1st drive, 1st drive works fine. power lead seams to be the problem
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 72 Answers
You'll have to change the power connectors
Posted on Dec 26, 2009
Shifts into 1st and 2nd gear, but not into drive
Well go get your car fixed by a mechanic or it something might be jammed inside
Feb 12, 2014 | 2001 Dodge Intrepid
I need to wire 3 woofers but 2 are dual voice coil and one is single voice coil
sure, if you wish to wire them all together, wire the first dual voice coil subs first voice coil negative to 2nd voice coil positive, second voice coil negative to single voice coil sub positive, and single voice coil negative to 2nd dual voice coil subs 1st voice coil positve (again with the second dual voice coil sub, run the first voice coil negative to the 2nd voice coil positve) your speaker leads will be attatched to first dual voice coils 1st voice coil positive, and 2nd dual voice coils 2nd voice coil negative)
Apr 01, 2013 | Kenwood KAC-8104D - 1000 Watts Class D...
2nd tv will not find signal after electric power cut
usually a surge like that can damage the circuitry
Jul 21, 2012 | Televison & Video
TRANSMISSION
I ahve already answered this question on your other post.
Jun 21, 2012 | Cars & Trucks
When I put the disc in to be copies and then the blank discs i press the green start button and it display target drive not ready. How do I get it to copy onto the other discs??
One of the "target" CD-writers is not working -- either the "data" cable is not connected, or the "power" cable is not connected, or the drive itself (either the "spinning" motor, or the "laser") has failed.
Presumably, you don't have to fill "all" the trays, in case you only want to make a few copies of the "source" disk.
So, make a few attempts, with the "source" disk in the "source" drive:
1. put a blank disk into the 1st "target" drive,
leaving the other targets "empty", and press the button.
If it works, then the 1st target drive is OK.
2. put blank disks into the 1st and 2nd "target" drives,
If it works, then the 1st and the 2nd target drives are OK.
3. put blank disks into the 1st and 2nd and 3rd "target" drives,
If it works, then the 1st and the 2nd and 3rd target drives are OK.
... and so on
If you get a "failure", then you now know which of the "target" drives is the "bad" drive. Either replace that bad drive, or change the cabling inside the unit to "bypass" that bad drive, and put a sticky-label on the face-plate of that drive, saying "do not use this tray".
Oct 16, 2010 | MicroBoards Quick Disc QD-123 (QD-123)...
Tranny problem 1st gear wont work really and its hard to get 2nd gear but 3rd,4th,and 5th work fine plus reverse works fine. do i need to replace the clutch? or is it sumthing else that wont let me get in...
There is problem in the gearbox.The sincronizers for a first & second gear are on the same gearswitch.Need to change them.Forget about the clutch.
May 16, 2010 | 1998 Volkswagen Jetta
Slides not working nor the power jack
Did you wire them in circuit? (hot lead to positive on 1st batt, which jumps to the neg on 2nd batt, and neg lead going to neg post on 1st batt, then to positive on 2nd batt) That would be for a 24v system, for a 36v you would continue to the opposite posts again.
Jun 02, 2009 | Ryobi Multi-Volt Battery Charger
Clutch slips
Hello, wheelies mm not good for your gearbox or clutch, 1st off is the gearbox working OK, does it jump out of 2nd gear under hard acceleration? then we can move on from this point,
Ian
May 26, 2009 | 2004 Triumph Daytona 600
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
71 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
