Question about D-Link DIR-600 Router
My DLink (DIR-600) router is not working. I've tried resetting the router, and re-installing it. I'm able to get internet connection straight from my modem to the computer, so I know it's something wrong with the router.
5 Suggested Answers
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
SOURCE: My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Posted on Jul 21, 2009
  • 115 Answers
SOURCE: how to install dlink dir 600 router
THIS SITE HELP YOU
HOW INSTALL DLINK
http://pdfdatabase.com/d-link-dir-600-installation-manual.html
Posted on Mar 25, 2010
SOURCE: my dlink dir-600 wont connect ot the internet.
my dlink wireless router cant connect to internet when i add it to my computer. its 2nd led lidhts orange.
Posted on Aug 18, 2010
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
How to change password of dlink router 600 without reset
the default dlink password is password or 1234
if that doesn't work then the password has been changed and you will need to reset the router to factory defaults. hold the reset button for 30 seconds while powered on.
Mar 04, 2012 | D-Link DIR-600 Router
Ever since the storm I can't get online wirelessly, I can't get on with the internet cable direct but not with the dlink 600. Please help.
check
1.- Cable leave modem is attached to Port WAN (they are others 4 ports LAN)
2.- In router Dlink DIR 600 led Internet in On or blinkling
3. using web browser type http://192.168.0.1 (this is IP default )
4.- reset your DIR600, using a clip press in reset Hole 10 seconds
5. Try again using web browser type http://192.168.0.1
If connect, re configure your modem for your wireless network
Sep 14, 2011 | D-Link DIR-600 Router
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
My cable internet provider has provided me with an Ethernet cable which connects directly to my PC. My PC's MAC address is registered with the ISP. I use a PPPoE connection to access the internet with a...
put another lan card in pc
share your connection using ICS from network properties from first one
put a straight cable from pc to router
give the gateway of router to laptop
remember!! the class of ip's should be the same
you are done
Feb 04, 2011 | D-Link DIR-600 Router
Please help.... I have just purchased a dlink dir-600 wireless router and I can not connect to 192.168.0.1 from my mac.
For setup, you need an Ethernet cable connection to the router, WLAN needs to be configured first before you can use it to administrate the router.
Quick installation guide is here: ftp://ftp.dlink.de/dir/dir-600/documentation/DIR-600_revb_qig_multi.pdf
The default user name is "admin" with empty password.
If you suspect the settings are not at factory defaults, press the reset button at the rear for 20 seconds with the router powered on.
Feb 09, 2010 | D-Link DI 514 Wireless Router (DI-514)
D-Link DIR-600 Router Logo
1,365 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
