Question about Gateway FPD2275W LCD Monitor
Horizontal lines on my monitor
Ihave a 5 year old Gateway computer and monitor. I have receintly noticed a few horizontal lines at the top of my monitor. I have not dropped it nor has anything hit it. I am wonderin what might be causing these. They do not effect the picture.
  • Stephen Karper
    Stephen Karper May 11, 2008
    I have one horizontal line of pixels that are white. The whole line is white even into the mask at the edge of the monitor. The line doesn't go away even when i unplug the signal cable. When the monitor turns off the line goes away.
    Novelist:
  • 159 Answers
Lines on screens are usually caused by damage to the ribbons on the actual screen face itself (something only a few professional lcd repair shops can repair).
Sometimes caused by a bump, other times from over-wetting when cleaning, or dampness/moisture issues
The inverter-power board does Not control picture, It just controls the backlight bulbs and powering the video board.
Picture is powered from the video display board.
Posted on Jul 13, 2008
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
"Lines" or irregularities through the monitor image display
Check power supply section for bad caps with bulging top first, may be a sign of failing power supply: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Jan 27, 2010 | ViewSonic VX2235WM Monitor
My monitor suddenly appear a 'dead line' horizontally..
anything can be repaired if you have the money and are willing to spend it. However it would be better to get a quote and weigh up the pros and cons of replacing it cheaper than the repair A new monitor wilol also have 3 years warranty ( Samsung)
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Gateway FPD2275W LCD Monitor
Gateway FPD 1730 Monitor
What has happened is part of your back lighting circuitry has gone out. Yes it is repairable but can cost most of what a replacement monitor will cost these days. Check that out before spending the money. If the problem is only in the back lighting circuit then expect to spend about $100 for a replacement board.
LCD monitors lifespan depends on the quality. Normal use and you should get 2-3 years of reliable service minimum. The display itself is good for about 4000 or so hours of use or more. The problems that show up are always (well 99.99% of the time) are back lighting problems like you have experienced. You should turn it off by the switch when not using it as every hour it runs the screen save is an hour of usable life. Heat is not good for it so if your computer gets the dust cleaned out to keep it cool do the monitor at the same time. Once a year at least more if you smoke use gas heat and have pets.
Tube monitors have a much longer life but you have the size weight and poorer display to go with them. If you have to go back to a tube monitor don't go back to your 14 ask around and you should be able to get a 17 or 19 crt for free. Or expect to pay no more than $10-20 for one.
Jul 10, 2009 | Gateway FPD1775W Monitor
Shadow Lines Across Screen on Dell P1130 CRT Monitor
What sort of shadow lines? I assume you haven't just noticed the two horizontal lines 1/3rd up the screen from the bottom and 1/3rd down from the top from the internal stabilizing wires that all Trinitron CRTs have?
Jan 29, 2009 | Dell P1130 21" CRT Monitor
Horizontal lines on Screen
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Heavy white lines accross the screen
Replace it, it is going bad. I could tell you what would cause this such as bad driver IC etc. but bottom line is its five years old, you got your moneys worth out of it so bite the bullet and get a new one.
Feb 11, 2008 | Envision EN 9110 19" Flat Panel LCD...
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
I have a similar problem with a 2 year old Samsung monitor. I have tried to make a screen dump of it, but the horizontal lines do not show up then. This I have read indicates that the problem is in the monitor and not the video card.
Sep 17, 2007 | Computers & Internet
Lines across screen
The screen you have is almost certainly on the way out. This type of fault is in the Horizontal Flyback section of the Monitor. Usually components fault or age and change value, these lines are normally "Turned Off" so ya can't see them, that "Turn Off" circuitry is going faulty.. it will only get worse. I suggest a new, or 2nd hand monitor as they are so cheap these days fixing CRT monitors can be cost prohibitive.
May 10, 2007 | Gateway FPD 1510 15.1" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
358 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
