Question about Topeak Cycling
Setting up a topeak panoram v12 wireless bike computer
How do you set the wheel circ for the 2nd wheel in the initial setup?
4 Suggested Answers
  • 3 Answers
SOURCE: Need to replace part 6 of Topeak bike computer (model Panoram)
Just call/contact Topeak. In many cases they will send you the part as a warranty item at no cost to you. If not they can sell you what you need.
Posted on Mar 29, 2009
  • 3 Answers
SOURCE: i need setup instructions for my speedometer
Download the manual from Topeak's website:
http://www.topeak.com/Service_and_Tech/Downloads
dunnbiker
  • 8546 Answers
SOURCE: I have recently changed the
http://topeak.com/products/Computers/PanoramV12WideScreenWireless
Downloads in various languages on right.
Posted on Jan 13, 2011
On leisurerite spa pool what does code 1-3 mean
If your system is equipped with a circ pump, it may be configured to work in one of three different ways: 1)
The circ pump operates continuously (24 hours) with the exception of turning off for 30 minutes at a time
when the water temperature reaches 3°F (1.5°C) above the set temperature (most likely to happen in very
hot climates). 2) The circ pump stays on continuously, regardless of water temperature. 3) The circ pump
will come on when the system is checking temperature (polling), during filter cycles, during freeze
conditions, or when the blower or another pump is on.
Dec 06, 2016 | Pool & Spa
How to do a complete initial setup on olevia 542-b11
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Dec 22, 2015 | Olevia Televison & Video
Lost my instructions.....how do I set clock on Topeak V10c?
Download this user guide. There is a section that shows how to set your clock.
Topeak Panoram V10c User Guide
Hope this works
Jul 28, 2011 | Topeak Panoram V10c
My motorola c350 language has been changed. Now I cant read the language for what its getting difficult to change it to English. Please help
Download the user-manual from this site. http://www.motorola.com/mdirect/manuals/C350_gsm_User_Manual_E.pdf
Observe the menu map. From your main menu, you have to open more (It has box open icon). Under More, you have to open Settings(Two mechanical bolts icon).
Under settings, you have to go to Other Settings which is the 5th option.
Call Forward
Phone Status
In-Call Setup
Security
Other Settings *
Under Other settings, you have the following options:
Personalize
Initial Setup
Network
Car Settings
Headset
You have to select the 2nd setting, that is Initial Setup.
Under Initial Setup, you have the following options:
Time and Date
1-Touch Dial
Backlight
Zoom
TTY Setup
Scroll
Animation
Language
Battery Save
Contrast
DTMF
Master Reset
Master Clear
You have to select the 8the option, which is language(langua/idioma/langue).
Now from the options select English to set english as the changed language.
Jul 20, 2011 | Motorola Mobility C350 Cellular Phone
My c6 in bronco starts off in 2nd gear performs ok every other way.
P0700 Transm.Contr.System Malfunction 17084
P0702 Transm.Contr.System Electrical 17086
P0703 Torque Converter/Brake Switch B Circ Malfunction 17087
P0705 Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction 17089
P0706 Transm.Range Sensor Circ Range/Performance 17090
P0707 Transm.Range Sensor Circ Low Input 17091
P0708 Transm.Range Sensor Circ High Input 17092
P0710 Transm.Fluid Temp.Sensor Circ. Malfunction 17094
P0711 Transm.Fluid Temp.Sensor Circ. Range/Performance 17095
P0712 Transm.Fluid Temp.Sensor Circ. Low Input 17096
P0713 Transm.Fluid Temp.Sensor Circ. High Input 17097
P0715 Input Turbine/Speed Sensor Circ. Malfunction 17099
P0716 Input Turbine/Speed Sensor Circ. Range/Performance 17100
P0717 Input Turbine/Speed Sensor Circ. No Signal 17101
P0721 Output Speed Sensor Circ Range/Performance 17105
P0722 Output Speed Sensor Circ No Signal 17106
P0725 Engine Speed Inp.Circ. Malfunction 17109
P0726 Engine Speed Inp.Circ. Range/Performance 17110
P0727 Engine Speed Inp.Circ. No Signal 17111
P0730 Gear Incorrect Ratio 17114
P0731 Gear 1 Incorrect Ratio 17115
P0732 Gear 2 Incorrect Ratio 17116
P0733 Gear 3 Incorrect Ratio 17117
P0734 Gear 4 Incorrect Ratio 17118
P0735 Gear 5 Incorrect Ratio 17119
P0740 Torque Converter Clutch Circ Malfunction 17124
P0741 Torque Converter Clutch Circ Performance or Stuck Off 17125
P0748 Pressure Contr.Solenoid Electrical 17132
P0750 Shift Solenoid A malfunction 17134
P0751 Shift Solenoid A Performance or Stuck Off 17135
P0752 Shift Solenoid A Stuck On 17136
P0753 Shift Solenoid A Electrical 17137
P0756 Shift Solenoid B Performance or Stuck Off 17140
P0757 Shift Solenoid B Stuck On 17141
P0758 Shift Solenoid B Electrical 17142
P0761 Shift Solenoid C Performance or Stuck Off 17145
P0762 Shift Solenoid C Stuck On 17146
P0763 Shift Solenoid C Electrical 17147
P0768 Shift Solenoid D Electrical 17152
P0773 Shift Solenoid E Electrical 17157
P0790 Normal/Performance Switch Circ Malfunction 17174
Dec 20, 2010 | 1985 Ford Bronco
Hi sir, i want some details related to the gear
Dec 20, 2010 | 2006 Renault Fuego
Cycling Logo
280 people viewed this question
Top Topeak Cycling Experts
Michial Gueffroy
numbers819
Level 1 Expert
jimmarmor_ma
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
