Question about Stanley - Bostitch Powerslamt Professional Hammer Tacker - PC2K
Where can i find a reassembly diagram for a bostitch powerslam PC2K
  • 2,176 Answers
You can try Bostitch.com and type in your model number for a schematic. If you need more help let me know.
Posted on Dec 11, 2009
SOURCE:
Tip
Bostitch Nailgun dis-assembly/assembly
Follow the link below to access complete parts breakdown diagrams for your Bostitch Nailgun. Enter the model number (or beginning partial model). The diagram and part numbers will be displayed. This should be an aid in dis-assembly of the gun as well as a guide for replacing the O-rings.
Dan
Link: http://www.ereplacementparts.com/bostitch-parts-c-29443.html?gclid=COuu69jQ46MCFZxo5QodN2GLlg
on Aug 31, 2010 | Air Tools & Compressors
WHERE TO FIND A BOSTITCH BT160HL DIAGRAM?
No luck on a parts diagram. Try calling them at this number:
you can call Customer Support at 1-800-556-6696.
Heres the link to the instruction manual.
http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=knowledgebase.htm&LEFT=left_knowledgebase.htm
Aug 30, 2014 | Tools & Hardware - Others
Conbuston chimber cracked
I think you may be referring to item 79 on this diagram. Either way this shows all the parts with part numbers.
Bostitch GFN1664K diagram
Aug 23, 2012 | Stanley Bostitch GFN1664K 16Guage Cordless...
Compresor will not hold pressure
Some are push down to lock so you need to lightly pull up on the knob before trying to turn it. If the regulator itself is bad the correct one is part #AB-9051116 and is less then $10. Any Bostitch or DeWalt (the companies merged) can get this part for you. Here is a link to the parts diagram. It is item 108 and is called a pressure reducer.
Bostitch CAP2060P diagram
Aug 19, 2012 | Stanley Bostitch 2hp 6gal Air Compressor...
I have a bostitch 6 gal pancake compressor that won't build pressure past about 20 lbs. when I turn it off I don't hear air leaking out anywhere and when it's running it runs at a higher pitch ( similar to...
I'd pull the cover off to expose top of cylinder head and have a look at any intake air filter. In parts diagram, It appears there is a small one that would likely clog during the texturing process.
Jan 26, 2011 | Stanley Bostitch CAP2060P 105 Amp...
Just lately my bostich coil framing gun is blowing out air from the top when I pull the trigger.I opened it up and the valve was stuck open so I popped it back down.Its colder now so should I be...
Usually this happens with the lack of lubrication as well as small leaks in the O-ring seals. I would closely examine the seals. See the link below to see a parts breakdown for Bostitch nailers. Enter your model number and you will see the parts breakdown and part numbers. Use the diagrams as a guide for disassembly and reassembly.
Feel free to post any additional questions that you have. I have had my nailer for over 20 probelm free years. The key is lubrication.
Dan
Oct 25, 2010 | Stanley Bostitch Coil Framing Nailer
Fires like a machine gun without pulling triger. Close call
Bostitch N60FN finish nailer:
I replaced the o-rings and reassembled now when I put air to it the driver does not return and when I pull the trigger I get a "puff" sound.
Sep 07, 2009 | Stanley Bostitch N88rh Framing Nailer...
Stanley - Bostitch Powerslamt Professional Hammer Tacker - PC2K Logo
373 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
JOHN LAPIER
Jay Finke
Jay Finke
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
