Question about HP LaserJet 6L Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
I connected my LaserJet 6L to my new HP Pavilion PC with a USB to IEEE 1284 printer cable. I successfully loaded the driver and Vista receives the print job and ships it off the printer. No errors, and no print jobs left in the que. One of the green lights on the LaserJet flashes like it is going to print, but then just stops without printing anything.
  • Anonymous Feb 02, 2008
    Hi I've got the same problem, have you find a solution?
  • starwalker Aug 03, 2008
    It doesn't work NETWORKED to an XP system either, regardless of shutting off "bi-directional."
    I am using a HP avilion dv9207us Notebook PC with Vista Home
    Premium. I want to use my HP LaserJet 6L. Of course the HP Pavilion
    dv9207us does not have a parallel port, so I’ve successfully networked to an XP
    PC system that does, and successfully installed the HP LaserJet 6L.
    I
    have added the network printer to the HP Pavilion dv9207us. It
    however will not print to the HP LaserJet 6L over the network, and
    would seem to need something special at the Vista end to do so.
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Posted on Nov 21, 2008
  • 2710297 Mar 15, 2011
    Hi varsitythoo,
    your reply is very strange:
    1) if you really tested HP 6L on VISTA you should definitely know that hp.com doesn't have driver for VISTA as VISTA already has it, so why do you link people to WRONG link....
    2) where did you find USB port005 - when I connect USB-LPT cable the only USB001 port is available
  • 417 Answers
Hi there I think that vista has a problem with IEEE 1284 connections try setting the driver properties to no bi directional printing. If not then I suggest to get a HP jetdirect box so you can use the Cat5e network cable.
Thanks J
Posted on Jan 28, 2008
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
I am simply making a copy and it is printing super slow.
hELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. SOLUTION: Solution After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model.
THANKS.
Sep 06, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Does hp laserjet 5200 have netword printer
Here is your network guide for the 5200n printer
If you do not have the 5200n printer, it is not network. You will need a 'print server' ($100 approx). Get USB or Parallel, depending on the connection it uses.
Mar 30, 2010 | HP Hewlett Packard LaserJet 5200 Printer
I can't get hp deskjet 600c to work with Vista. Am using a IEEE 1284 to USB cable. HP site states Vista driver will automatically recognize and install printer, but my computer does not. Print manager...
The drivers for the 600C should be there in Vista, it should directly install the drivers. Check if the drivers is not in offline mode, right click and turn it to online mode. If the drivers were installed automatically when you plugged the USB cable, then the USB cable should be good enough.
Jan 27, 2009 | Office Equipment & Supplies
Hp laserjet 4001n
The cable you need to connect to your pc is a regular parallel cable. It is called, IEEE 1284 Bi-directional Parallel Cable.
If you intend to use the a USB port this is what you need; USB to DB-25. The printer connection of the cable is the same the only diffrence here is the USB female adapter for the pc.
Nov 14, 2008 | HP LaserJet 4100n Printer
LaserJet 6L with Vista using Parallel to USB Cable
It can be done tested by Thoo personally 6L printer prints well on vista too
The printer end should be connected to 25 pin parallel cable, converted to the USB on the notebook end of the wiring
To solve your printing problems locate vista driver, since i have tested vista works fine on HP 6L printers
make sure you select the correct O/S and assign in to the USB virtual port 05
After installing my vista can print perfectly well on test printout
Advise from http://www.bebo.com/andythoo
Technical support specialist: Thoo Wai Kiat
Nov 05, 2008 | HP LaserJet 6L Printer
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
HP LaserJet 6L Printer Logo
4,119 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
