Question about HP f1905 19" Flat Panel LCD Monitor
Screen is dark, power button flickers green intermittently. The cpu boots up and I am able to remote control the cpu via logmein. I know logmein adds its own video driver, however when I check the system components, there are no red x's and it says the monitor and video are working properly
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Oct 04, 2014
    President:
  • 2,187 Answers
Check then the cables. It may be loose pins on the connector or a bad cable. See if you can install the monitor on another CPU just to make sure that it is not the actual monitor has the problem.
Posted on Dec 11, 2009
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Monitor intermittent power problems. Horizontal green flickering lines
You have to check the ESR in tha caps in power supply with esr meter.
If you dont have one just replace all capacitors in the power section(there are severals of them)This is the simptom of low esr in the capacitors.
Return the monitor in factory settings.
Jan 28, 2014 | Dell Computers & Internet
Install internet explorer on iPad?
1. Sign up for a free account at www.logmein.com
2. Add your desktop with IE to your logmein account.
3. Install LogMeinIgnition on your iPad (cost $29.99, but well worth it).
4. Now you can access your desktop from your iPad (as long as the desktop is powered up and connected to the net) and search your MLS from your iPad via your desktop
Feb 12, 2011 | Apple iPad 16 GB 3G Tablet PC
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
Have a daenyx dv-833 dvd player
Good Morning,
Your connection is very easy so we should not have a problem isolating the problem.
We just have to go slow step by step.
First lets just check the Yellow cable just to be on the safe to side sure it is connected properly on the back of the DVD player and on the Televison.
Second, If the connectionn is secured. Turn the DVD player on, make sure you do not have a disc in the tray then turn the DVD player off.
Make sure the battery on the remote control is a fresh new battery (process of eliminattion).
Hold the remote control in front of the DVD front panel.
Turn the DVD player on with the remote control. Look on the front panel of the DVD player, it should read no disc. Press the Pro.Scan button "once". (Have you notice a flickering on the Television Screen).
If no flickering on the TV screen, press the Pro.Scan button again, ( this will be the second time). Have you notice the flickering?
If not, press the Pro.Scan button again ( third time). Have you notice a flickering on the TV screen?
Did you not notice on the LED of the DVD player if it read anything when you pressed the Pro.Scan button?
Try the above procedure again if your picture did not resume. If the picture resume in black and white, do not press the Pro.Scan button anymore.
Let me know the outcome up to this point.
Thanks,
Mike H.
Nov 02, 2008 | Televison & Video
3 long beeps of my elitegroup ecs green 320
If you cangatehr this much of information you are no less than a computer engineer. Nobody needs to build a car to change its tyre. If you arrange a spare HDD and RAM, remove the original HDD and try to install windows on that. And if problem persists do the same with RAM also. I am sure you could solve this problem yourslef.
Oct 06, 2007 | EliteGroup ECS G900 Notebook
3 long beeps with my Elitegroup ECS Green 320 laptop
Let's start with the most overlooked reason. Sounds like the battery died. Is your laptop's battery fully charged. Plug it in over night and give it a good chance to recharge the battery. Then turn on your laptop WITH the power cable attached. Did this solve your problem? If not we'll go to the next step.
HP f1905 19" Flat Panel LCD Monitor Logo
153 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
