Question about DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad
Air condition on my home is blowing cold air when the heater is on
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
NOT enough informations.
Posted on Dec 14, 2009
The heater in my excel blows cold air only . The dimist still works just no heat what should i look for?
There are several things that you can do about a heater blowing cold air, but if you keep running into problems then it might just be time to call in a heating repair company. If need be, here is a useful article on: HVAC installation cost, and how to get a fair price. How serious of an issue this is depends greatly on where you live. If you live in the north (Bozeman, MT, etc), then I'd recommend you have your furnace inspected annually to ensure that it is working properly. I'd also recommend that you install a backup means of heat...just in case. ASM has over 25 years of heating and air conditioning experience. If you have questions about a heater blowing cold air or any other HVAC related topic, try the ASM Air Conditioning and Heating Blog or if something your contractor is telling you seems expensive or doesn't sound quite right, consider using our Online Air Conditioning Consultation Service.
Jul 27, 2016 | Cars & Trucks
My air condition only blows out cold air not hot
Turn your air conditioner OFF and turn your heater ON. Air conditioners were designed to blow out one temperature of air... COLD.
Nov 13, 2014 | 2004 Mercury Grand Marquis
My 2006 6 Santa Fe will get heat after it warms up but after about 30 minutes will start to blow cold air. Any ideas.
Right when it goes cold check the heater pipes are hot to work out where the problem lies ,if the pipes go cold then its circulation problem if the pipes are hot then its a problem with the control unit ,its has a microprocessor to work the climatic control and i suspect the later but them i am often wrong in these cases with all this fancy electronic gear on modern cars.my ideal is a radio with a volume controlwith built in on/off and a tuning knob ,heater controls where its a lever to turn the heater on or off ,a handbrake that lock the back wheels up at 30mph and nice thin steering wheel with the horn in the middle of it .But i think iam showing my age here
Nov 05, 2014 | 2006 Hyundai Santa Fe
I have a 1999 323i BMW. The AC doesnt blow cold (on cool days it blows cool temperature but not common A/C Cold Air, Hot Days it blows Warm/Hot Air). The heater blows warm air but definitely not common...
First things first.....You must have the air conditioning system hooked up to an a/c system machine and then checked for leaks and also read low and high side pressures. If there are leaks then low Freon (R134a) content and low refrigerant oil can cause the a/c system to not engage the a/c compressor which basically means you will not have proper defrost functionality nor regular air conditioning. Most shops, when working with your air conditioning, will install air conditioning dye to assist them in locating leaks and is the first step in diagnosing all a/c systems. Post the findings after thw
Jan 21, 2018 | 1999 BMW 323 Series
The air conditioning system will only blow cold air. Regardless of the mode, I can only get cold air. Can you give me an idea on how to fix the problem? Thanks Don 615-653-3834 drcamp117@comcast.net
The air conditioning is supposed to blow only cold air. Are you trying to get the heater to blow hot air? Make sure the temperature selector is in the hot position.
Dec 19, 2010 | 2002 Buick LeSabre
98 dodge stratus air conditioning and heater not working.
need more info? Heater blowing cold air? Heater not blowing at all? If neither heat or air are blowing then it's just the blower fan. Easy to replace and fairly cheap.
Mar 22, 2010 | 1994 Plymouth Voyager
Heater blowing hot air when dial on cold
2 possibles: 1- blend door actuator, or 2- blend door broken, both require removal of the dashboard assembly to access....GL
Jul 05, 2009 | 1999 Ford Taurus
2003 mitsubishi galant es 4cylheater blowing nothing but cold air
This may be a solution:
I had a similar problem at the beginning of this winter.
My heater was blowing cold air.
My solution:
Heater Temperature control cable, about $10 from dealer
Install, about $70, at my local Firestone
Apr 09, 2009 | 2003 Mitsubishi Galant
Heater on blowing cold on driver side and hot on passenger side
This sounds like an air damper is not operating, maybe a cable sticking or a vacuum line come off.
Jan 29, 2009 | 2001 Jaguar S-Type
DeLonghi Trane 5t Rooftop Air Conditioner Ycy060g1m0ad Logo
53 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
