Question about Mitsubishi WS-55809 55" Rear Projection Television
It won't power on. tries to come on, green light blinks several times and then powers off, then continues to repeat the process. the diagnostic code is 1 blink then 2
  • mrtfb Dec 12, 2009
    Ok. I tried all that. Still same situation. Can you tell me the exact parts, where to get them and how to do the repair myself. If so I would be greatly appreciative. Thanks.
  • mrtfb Dec 17, 2009
    Where are the convergence chips, Pico fuses, and IC's located?
  • Mitsubishi Master
  • 5,138 Answers
STK ICS convergence they are big black ICs will have Part number on them example STK392-570 --pico fuses Look like resistors but are green or yellow 5amps 6amps they are mostly in power suppy side .replace Both of your STKs and dont worry about the pico fuses if any of them where Bad set would not do anything! Call Mats Electronics for Parts 1-800-628-1118
Posted on Dec 18, 2009
  • 10,515 Answers
You could Download the Service Manual From the Link below :-
http://nodevice.in/manual/newmans/V18_Service_Manualpdf/get15995.html
That would have all the Details Regarding Error 1-2. You could order the Capacitors/ IC Online or Go to Radio Shack to have those and Solder it to get this Fix.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems it is a problem with the convergence chip going bad and needs replacement however, before those please follow this:
1). Plug the TV into a power strip.
2). With TV plugged in, light blinking Press the system
reset button and hold while you turn the strip off then back on again and then continue to hold the reset for another 30 seconds. When you’ll release the reset button the light should blink for about 2 minutes & then stop and the TV will turn on.
If after doing all this still the issue is not resolved then you have then definitely it is a bad convergence chip that has shorted; it takes out one or two Pico fuses in the set's power supply---the set detects no voltage to the convergence chips and shuts down. You might have to replace the Pico fuses as well. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Tip
MITSUBISHI PROJECTION DIAGNOSTIC FEATURE
If you have a Mitsubishi rear projection where the model number begins with WS or in some cases VS and the set turns on for a moment (green light comes on and goes off) Do the self check most models made from 1999 through about 2005 have:
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
This does not apply to sets with a WD model number, they have different codes.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
If you get one, you can post a question in the Free section here attention:
SD TECH AND I WILL TELL YOU WHAT IT MEANS AND MAY BE ABLE DEPENDING ON THE ERROR TO TELL YOU HOW TO FIX IT.
Mitsubishi was one of the first to have this feature so techs could with ease know where to look for whatever was wrong--a time saver and several other companies followed suit.
Again: Post either a free question or a Premium question here Attention: SD TECH and I or some other expert will be happy to assist you.
on Aug 12, 2010 | Televison & Video
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Power light flashs off and on and pc clicks
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Well, I was sure that the voltage selection switch was in the right place. And I found it highly unlikely that the processor power cable would suddenly unseat itself. Ugh.
Then I had an idea. I flipped off the surge protector and then flipped it back on. Tada! No more orange lights. Weird. The moral of the story: try the simple stuff first.
I hope this helps and please dont forget to rate my answer. Thank you! :D
Apr 28, 2010 | Dell OptiPlex SX280 PC Desktop
The tv repeatedly turns on then off
First area to check out is the power supply of the set.
Jun 14, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Will not reset, light blinks 8 times
Hi there you can try this
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
All The Best Pineworks
Jun 04, 2009 | Canon I990 InkJet Photo Printer
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
