Question about Sony RDR-GX355
GX355 won't power up. HDMI blue light is illuminated.
  • 10,515 Answers
Usually this is a Problem that needs Disassembling. First of ALL, unplug he Unit for Few Minutes. Make sure all the Output/Input Devices are Unplugged. Turn it Back ON. ( Say 15 Minutes ). If it still does not Respond, you need to Open the Player.
Note - This Might Void the Warranty, if any. Only Perform if you are Good at Electronics.
http://www.maxim-ic.com/appnotes.cfm/an_pk/2947
Read the above Link.
The power circuit for the DVD and the VCR are separate look for a open diode and transistor in the circuit that supply the DVD. Once you open it, also Check for the Fuse to make sure it was not Blown.
Download the Service Manual from :-
http://nodevice.in/manual/sonymans/manual4241pdf/get5756.html
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
My Sony mhc gx355 stereo red light flashes buthe it's not powering on
Try disconnecting all the speakers, the red light may indicate the player is in "Protection" mode. That mode is triggered by a short in the speaker voice coil or the wiring to them.
Feb 25, 2017 | Sony Audio Players & Recorders
Need color list for factory stereo for 99 cutlass
Constant power orange switch power ground Yellow illumination Gray dimmer Brown antenna trigger antenna pink left front + tan -gray right front + light green - dark green left rear + Brown - Yello right rear + Dark blue - Light blue
Jul 29, 2011 | Car Audio & Video
Where the fuse box to a 88 ford thunder bird 5.0 liter
The fuse panel is located underneath the dash, to the left of the steering column, next to the emergency brake pedal. You need to remove the under-dash insulation to access some parts of the fuse panel.
If it doesn't have a diagram inside the box, here's one I found online: http://www.coolcats.net/tech/reference/images/fusepanel.jpg
1 15A Lt. Blue Stop Lamps, Hazard Warning Lamps, Speed Control, Cornering Lamp Relays 2 6A - CB - Windshield Wiper/Washer Pump 3
Spare - Not Used 4 15A Lt. Blue Taillamps, Parking Lamps, Side Marker Lamps, Instrument Cluster Illumination, License Lamps, A/C and Heater Illumination, Radio Illumination, Digital Clock Illumination, Autolamp Relay 5 15A Lt. Blue Turn Signal Lamps, Electronic Day/Night Mirror, Lighted Vanity Mirrors *, Backup Lamps, Illuminated Entry, Keyless Entry, Cornering Lamps 6 20A Yellow Rear Defrost Timer, Chime, Back-Up Lamps, Cornering Lamps, Rear Reading Lamps, Trunklid Release, Digital Clock Display, Illuminated Entry, Anti-Theft Module, Turbo Buzzer 7 15A Lt. Blue Fog Lamps (Turbo Only) 8 15A Lt. Blue Courtesy Lamps, Key Warning Buzzer, Illuminated Entry Module, Glove Box Lamp, Door Lock Relays, Radio Memory, Cluster Memory, Outside Mirrors, Tripminder Module, Analog Clock, Anti-Theft Relay 9 30A Lt. Green A/C Heater Blower Motor 10 20A - CB - Horn, Cigar Lighter, Fuel Filler Door, Flash-to-Pass, Speed Control 11 20A Yellow Radio, Tape Player, Premium Sound Amp, Power Antenna, Graphic Equalizer 12 20A - CB - Power Seats, Power Locks, Keyless Entry 13 5A Tan Instrument Cluster Illumination, Radio, Climate Control 14 20A - CB - Power Windows, Power Moonroof 15 10A Red Taillamps, Rear Side Markers, License Lamps, Electoluminescent Coach Lamps 16 4A Yellow Electronic ATC 17 15A Lt. Blue Electronic Cluster, Tripminder Display, Fuel Gauge (non-electronic cluster), A/C Clutch, Speed Control Module, Graphic Warning Display Module, Electronic Blower Speed Controller 18 10A Red Warning Indicator Lamps, Autolamp System, Throttle Position Sensor, Low Fuel Module, Dual Timer Chime, Tachometer, Washer Fluid Level Indicator
May 20, 2011 | 1988 Ford Thunderbird
I put a new car stereo and system in my car. Now the parking lights won't turn off. Is this a security mode on the car? Or is it from the wiring? It is a 2006 Kia Spectra EX.
Usually the brown wire is for illumination. If you have supplied power to this wire some how it will keep these lights on. If you got wiring schematics with the stereo recheck your work.
May 07, 2011 | Kia Spectra Cars & Trucks
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
My Wii is all plugged in but the light is out like its unplugged. we keep unplugging and plugging it back in but it is still not working, how do I fix this?
I think you are asking about the slot illumination for the wii this is how you change it:
  1. Access the Wii System Settings.
  2. Move the cursor over the blue arrow on the right and and select it once to reach System Settings 2.
  3. Choose "WiiConnect24."
The following options will be available:
  • WiiConnect24
  • Standby Connection
  • Slot Illumination
Choose Slot Illumination
Slot Illumination (Bright, Dim, and Off)
WiiConnect24 can let you know when it has received data by making the Wii console's Disc Slot illuminate. Select the option you want, then confirm your selection.
Bright: The Wii's Disc Slot will display a bright blue light when WiiConnect24 has received new data.
Dim: The Wii's Disc Slot will display a dim blue light when WiiConnect24 has received new data.
Off: The Wii's Disc Slot will not blink when WiiConnect24 has received new data.
Feb 27, 2011 | Nintendo Wii Console
I run my finger over the power button but it wont turn on.
You don't need to run your finger across it, with the red light illuminated, press and hold the power button for 3 seconds you should hear a beep then a blue/green light should illuminated. If you see no light ensue the MAIN power switch on the back is switched on.
Rylan
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
My sony rdr-gx355 will not turn on. The blue HDMI light is lit up but nothing else will work
Same here. I'm trying the "unplug and wait 40 minutes" solution like some of the Sony Blue-Ray solutions.
Nov 03, 2010 | Sony RDR-GX355
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
Sony RDR-GX355 Logo
150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
