Question about Gigabyte GA-EP43-UD3L Motherboard
Hi, I have just purchased a new system and after setting it all up, it wont boot at all. What happens when I turn the machine on is: 1)My monitor displays nothing (it's status light stays amber although its 'connect to source' message goes away) 2)The motherboard makes no sounds at all (no beeps etc) 3)The cpu fan try's to spin but fails (it 'judders' once then stops) 4)The motherboards phase lights are green, green, yellow, red for about 5 secs then turn off 5)My keyboard numlock icon lights up. The steps that I have taken to diagnose the situation is: 1)Ran the system with 1 block of ram (trying all the ram slots) 2)Ran the system with only the cpu, gfx card and ram - in the case 3)Ran the system with only the cpu - out of the case (check for shorts) 4)Used the 'Reset CMOS' jumper then tried all of the above 3 steps Every test I have done produces the same results (top list). Is there anything that I am missing / doing wrong? Or is it a case of Dead On Arrival for the motherboard?? Any help would be greatly appreciated as I am completely stuck (I have built quite a few machines before but am no expert). The system specs: MOBO: Gigabyte GA-EP43-UD3L CPU: Intel Core 2 Quad Q9650 LGA775 'Yorkfield' 3.0GHz RAM: Corsair Dominator 4GB (2x2GB) DDR2 XMS2 PC2-8500C5 TwinX GFX: PALIT GTX260 SONIC OC Edition 896MB PSU: CoolerMaster 600W Silent Pro HDD: Western Digital WD5001AALS 500GB
  • 2,229 Answers
You could try another power supply. Otherwise, I'd say it's DOA
Posted on Dec 11, 2009
Testimonial: "I have tried 2 power supplies with it (one brand new) guess I should send it back. Thanks"
  • Jay Green May 07, 2012
    I found this to work on my motherboard => in 2 ways. I had several SATA HDDs connected just as independent expansion drives. I connected them while the system was powered. No issues until I tried to reboot. I had to disconnect most of the expansion drives until after the OS booted, otherwise the phase LEDs would light up. I moved from a 500W to a 750W PSU. never had the phase issue again with the expansion HDDs connected. "My guess" the drives cause too much of a current draw and the MoBo is not able to POST properly. This may not be the real cause, but so far I haven't found a way to dispute it.
4 Suggested Answers
babes_ganda0
  • 381 Answers
SOURCE: the phase 4 led on my gigabyte ep43-ud3l ights up
hi..the mother is need a complete the supply on board pin..then double cheek the memory..thanks..Good Luck...^_^
Posted on May 13, 2009
  • 42 Answers
SOURCE: GA-EP43-UD3L Having problems installing motherboard.
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Posted on Jun 20, 2009
technical114
  • 1851 Answers
SOURCE: Problem with the Gigabyte GA-EP43-UD3L
Trying to help you, please clarify me if the beeps are short or long ones, or some (how many) shor followed by some (how many) long ones. Don't worry, leaving the computer at "beeping mode" won't hurt it. Sorry for the details but these kind of codes identify if it's a motherboard, or CPU, or memory error.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Oct 02, 2010
When i turn on my PC toys CPU and emachines monitor it says disk boot failure enter system disk
hi,
you have two option as follows:
1.when you start PC press F2 enter in BIOS set it to boot from HDD then restart,if this step does not help then number 2
2.reinstal the OS
Sep 26, 2012 | E-Machines eMachines Desktop PC
Hi there. I have just purchased a new ASUS Radeon 6770 graphics card. I have just installed the hardware. When I turn the PC on, I can't get any video signal output from either the onboard graphics, or...
Hi granttoolmad
Shut down computer and disconnect power plug . Extract new graphics . Reconnect and reboot computer , you should get video back . Install the driver with the cdrom you purchased with the card . Shut down . Install new card . and boot your machine . Wait for Windows to recognize the card . Shut down . Connect your monitor to new card . Reboot .
Best regards ,
fanaudi .
Jul 04, 2011 | ASUS Computers & Internet
Picture is not coming on monitor when I boot my system.System beeps while booting.I can also able to shut down the system after booting assuming it is on windows desktop without viewing anything on...
Things to try:
1. Check if your monitor is turned on.
2. Turn your monitor's Brightness and Contrast settings to the highest.
3. Try replacing your monitor's cable a with a new one.
Mar 12, 2011 | Computers & Internet
Acer Aspire One wont turn on
Hi there
It sounds like the hard drive is faulty and has some bad sectors on it. Take the hard drive and boot the machine to rule out any other possibilities of problems with the laptop itself, if it stays on and just says hard disk not found you know its the hard drive.
You need to have the hard drive checked for possible bad sectors and have them repaired or maybe even have to purchase a new drive.
Good luck
Jan 15, 2009 | Acer Aspire One PC Notebook
Monitor Shutoff Problem
Power management is a tricky business for a lot of users. I would recommend setting a screensaver up if you already have not and turning that part of Power Management off.
XP:
Right click on the desktop, select Properties, click the Screen Saver tab, set up your screensave. Then on that same tab, click the power button at the bottom, changet the turn off monitor setting to 'Never" click apply. Hopefully by never engaging the poower management, this will eliminate the error.
Jan 08, 2009 | E-Machines eMachines Desktop PC
Moniter is black but has power
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
Dec 19, 2008 | HP Compaq FP5315 15" LCD Monitor
My hp desktop pc model hstnc-006p-mt wont start up after installing new psu
hi!!!!
so there is a setting in your computer that will not be stand by
so!!! here your gonna do
step
1.go to start menu
2.setting and then control panel
3.click to the power option
4.try to set the monitor, hardisk and system
5.set them in "never"
if there is anything problem try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Media Center m7250n (ED842AA) PC...
Monitor
hi the problem isnt in the screen its in your configuration in the bios or your OS go insdie the bios menu and choose the default option and save it good luck
Apr 02, 2006 | NEC LCD1915X (Black) 19 in. Flat Panel LCD...
Gigabyte GA-EP43-UD3L Motherboard Logo
332 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
