Question about RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag
Gas WeedEater starts bur runs only minutes
And the plug is usually fouled.
Made a new tank of gas with oil added again.
Changed the spark plug.
It helped it run longer but not like it did before.
This one has always run great.
2 Suggested Answers
  • 7 Answers
SOURCE: I have a weedeater leaf blower that will start
sounds like the carby needs an overhaul. bellows in carby that **** up fuel may need replacing
Posted on Jul 03, 2009
Testimonial: "I replaced a gasket in the carb. thanks"
Smoke came out of the leaf blower while using it and it will not start again. What to do?
1 obtain new spark plug
2 completely empty the gas tank including the gas lines
3 Carefully remix proper amount of gas to oil ratio and try again.
Most Gas leaf blowers / weed eaters run on Gas mixed with Oil, if too much oil is present smoke will appear the spark plug will foul and it wont start. additionally nO oil at all in the gas will cause the engine to smoke seize .and never ever start again. so if you can still pull the starter rope try the above
:note: most small bottles of oil mix will do two gal
May 02, 2018 | Garden
Put new gas and new oil in and tried to start. Would stall in few seconds when could start. There is fluid dripping from the filter area
Hi Anonymouse:
I'd be checking to make sure that the correct fluid in the correct amount was added to the correct place.
Start with the oil. Check the dipstick or indicator level. Too much oil will stop the engine. Sometimes gas get accidently put in the oil filler if an inexperienced person is helping with the maintenance.
Gas.......... Make sure that oil was not accidently added to the gas tank. Drain the carb and put fresh gas in the gas tank.
Spark plug.;.... pull and check for fouling. Replace if not really clean. Check for hot blue spark before re-installing.
This should get you back digging up the garden very soon.
May 15, 2015 | Garden
Craftsman weedeater will not start
remove the spark plug , an go in dark area, pull start , do you see sparks , or just grab the plug an pull it, does it hurt.(ground one side of hand to the metal so it don't course thorough ur body.
so you have spark or not ,
no ,then theres the answer magneto is shot.
yes, then take off the filter an give it some gass or just spray a bit in cyl as you put the plug back from testing the spark.
does it cough or run when gas is added into some port
no then the cyl is cracked or needs oiled , spray some oil an gas in the head w/spark removed, let it set .
May 07, 2014 | Garden
Our Husqvarna YTH2148 mower has been in the shop twice and we can't figure out what's causing black, sooty fouling of the spark plugs.
Hi, change the engine oil. It has become contaminated with fuel. Also fit an inline fuel tap and turn it off whenever the mower is not in use. Basically the carby has leaked fuel into the engine oil, the engine then draws the fuel vapour from the oil through the crankcase vent into the carby creating the problem you have. Regards Phil.
Jun 03, 2012 | Husqvarna Garden
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
2005 Honda CR 85 R keeps fouling spark plugs
Hi, William and the usual suspects are:
1. The first thing to do if your spark plug has been fouled is to check the air filter. If it's really dirty, that makes it difficult for air to get through to the engine, causing a rich condition. Either clean it thoroughly with some Air Filter Cleaner or buy a new filter. Before you put it back in the air-box, treat with some air filter oil or spray. "WARNING" adding too much oil can also clog up the filter, resulting in another fouled plug.
2. While the gas/oil ratio doesn't equate to what the jetting is, you can still foul plugs, or worse, if the mixture is wrong. Depending on your bike, it's best to look at your owner's manual for the correct ratio. For most 2-stroke motocross bikes, a ratio is 32:1 or 40:1, the gas being 32 or 40, and oil being 1. For those that don't it, it means that for every 128 ounces (one gallon) of gas, you add 4 ounces of 2-stroke oil for a 32:1 ration, or just over 3 ounces for a 40:1 ratio.
If you have too much oil in the mixture (such as 12:1), then you will probably end up fouling the plug because it is more difficult to burn that much oil. Don't try to cut corners with the oil though, because it's very important for your dirt bike's engine. 2-stokes need the oil for lubrication on the cylinder walls, so if you don't have enough (or any for that matter) then the cylinder walls will run dry, causing it to overheat and seize the engine very quickly. So it's very important that you put in the right mixture pre-mix to your 2-stroke gas tank.
Also, 2-strokes have reeds that air and fuel go through into the cylinder, so if they are cracked or broken the bike will not run right. This could cause the plug to foul, so before you go out and buy anything expensive, make sure the reeds are still good.
3. While this usually isn't the main problem, it could be that your spark plug isn't burning hot enough. Having a hotter spark will ignite the fuel stronger, leaving less residual gas/oil in the cylinder that could cause the plug to foul. This "ISN'T" the best choice, but I'd say it's safe to go one plug hotter than stock. Keep an eye on the plug color you're looking for a light tan color anything whiter and you could burn a hole in your piston. Spark plug manufacturers aren't always the same, so make sure you find out how they rate them.
4. Almost every motocross bike comes rich from the factory (especially Honda 2-Strokes when they were being made). It's usually a pretty simple fix, but many riders are too lazy and would rather continue buying plugs instead of spending a few bucks on jets.
5. Piston rings badly worn or broken.
6. Faulty ignition coil low output.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
CR85R fouling spark plugs
06 CR85 Fouling plugs
CR80R RB CR85R RB 1995 2007 Workshop Manual Models Download Manuals... $15
http://www.partsfish.com/page/oem-parts-for-honda
Honda CR85 Expert Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 18, 2011 | 2005 Honda CR 85 R
My wife put a small bottle of 2 cycle oil directly in the gas tank of my Weedeater edger and then added gasoline. Bless her heart she tried to help me out. Emptied the tank and refilled it correctly but...
Take the air filter off and make sure it is not soaked with oil. Leave if off. Get some carburetor/choke cleaner and have someone spray it into the carburetor throat while you are pulling the starter. You may have to open the choke to do this. You may also need to pull the spark plug and clean it if it is oil fouled. Hopefully, no real damage has been down and the machine will eventually start.
Nov 28, 2010 | Poulan Garden
One year old Poulan weedeater starts right up but will only run with choke about half way on. Warm it up that way but it does not run any better. New gas, new spark plug, clean air filter. The weedeater...
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag Logo
141 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
