Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE rear projection HDTV
For the last couple of days when I try to turn the set on it will immediately turn off then back on and off again three times then stays off. I cant figure out what the problem is. I would very much appreciate some help with this problem.
  • Anonymous Feb 01, 2008
    Mine is doing the same thing, I have no clue what to do.
  • Anonymous Mar 23, 2008
    I had the same problem. The TV would shut off an on. The Sevice Tech came 6 months ago and replaced the driver board, we had to call back because the TV started shutting off and on again. With the same problem!
    Problem Solver:
  • 8 Answers
This problem seems to be very common. Do a search on google or even on this site and you will find all sorts of stories of smoke, sparks, flames and melted plastic with these televisions. I believe this common problem with large sparks and flames warrants a recall. Report it to the Consumer Product Safety Commision.
https://www.cpsc.gov/cgibin/incident.aspx
Posted on Feb 07, 2008
I Have the same problem with mine. when i go to turn it on the green lite comes on then blinks then shuts of. I was told that it was the bulb's so we open up the back to see. we tried to see if it would turn on, when we did one of the circuit board started to smoke!
so if any of you knows what model that circuit board is could you e-mail me at backwaterdanny@yahoo.com
Posted on Feb 06, 2008
I have a GE HD TV Monitor, after shutting the TV off for the day...you can not turn it back on. Everytime I try and turn it back on...it trys to start three times, then makes me wait for aprox 1 minute to...
that sounds like the CP150, CP120 and CP114 capacitors have failed. The RCA repair kit by that same name works for your model GE also. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions for the repair.
Feb 16, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hey guys please help another Fixya expert w/52''ge projection tv
Replace CP150 and the HOT transistor and that should take care of it. CP150 is most likely the cause
Jan 24, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
TV turning off
INtermitant problems as the are called usally mean bad solder connections...the joints between electronic components. this set when it has a problem shuts down. This is safty cuircits. It could be a connector. when the set shuts down. it locks out for a period of time.. DO you have to uplug it to reset it? IS there any sounds. Without know more i would guess its high voltage.
Dec 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
D52gw12 ge television smokes
Please give complete service # off back of set so I can research
with accuracy........T.
Sep 07, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
My TV turns on and off randomly!
Remove the rear cover & turn set on, pull all the connectors off one at a time and push back on. I have had loose connectors cause this problem, and by doing the above has fixed it. Note do the pull off and push back on of the connectors, with the tv unplugged from the AC outlet.
Jul 14, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
