Question about Gemmy Toys
How do I get 6' Tall Collapsible Santa to full size
I bought a pre-owned collapsible animated santa (Gemmy brand) and I dont know how to get it to full size.
The one i have has a large button on the base you just step on that button and santa pops up to full size and reverse it when you want to collapse again
Posted on Feb 29, 2012
  • italia
    italia Jan 01, 2014
    I have one and you need to gently press his sholuders down untill he relases and pops up
  • 5 Answers
SOURCE: i need instructions on how to pop up my gemmy
It is suposed to pop up once you press on its shoulders. Once you press them both down you will hear two clicks and release and it will pop up. Mine was jammed and when I pressed it down on the shoulders only one side would click, the other side would not click so Santa did not pop up to full size.
It was jammed on the white area of the stocking, the material got tucked inside the click mechinism prevent it from making proper contact. To fix it I simply pulled the white stocking material up (as if you are going to roll the pant leg up) and then when I pushed the shoulders down after that it opened up just like it should!
Posted on Dec 06, 2011
SOURCE: I have a lifesize grinch
if you have the same on as I do, gently pull off his head - there is a large dial that you turn to unlock him into the standing position.
good luck
Posted on Dec 18, 2010
Testimonial: "Thank you so much,I would never have figured that out..... Peggy !!!!!!!!!"
SOURCE: Gemmy Santa Bear mouth does not move
The repair listed is just the start. You can, with a lot of careful work, remove the bottom of the mouth, but your work has just started. You will then have to remove the rod that holds the mouth rod to the mouth slide lever "spine". It has a small spring at the top and I found it easier to disconnect the spring prior to repairing the unit. It is glued in quite well so I suggest a Dremel tool to cut the sides off which you will enable you to remove the rod. Then you can remove the head from the spine without difficulty. Now you will see that the problem is as stated, the string that pulls the mouth open has separated from the motor shaft. The cause of this problem is that the grease that the mouth slide lever rides on has migrated to the string, and then, softened the glue, which allows the string to separate from the motor shaft. Now, clean the shaft and replace the string. The original string is nylon. You should use similar material, NOT cotton string or a rubber band. You can't use the old string as it is soaked with lubricant. Use a good super glue to bond the new string to the motor shaft. Next, test the unit to make sure that the mouth slide lever operates properly. Reassembly of the unit would be: remount the head to the neck, then reattach the mouth rod to the mouth and then reattach the mouth and rod to the mouth slide lever.
Posted on Aug 29, 2009
SOURCE: gemmy 5 ft animated singing dancing santa claus christmas life size and it as stoped working, can you help, please :(
Ours that we bought at a garage sale did the same thing. We had to get a new cord. (Someone had put the wrong plug in cord in the box) GL
Posted on Nov 27, 2011
SOURCE: I have the 48" gemmy singing, dancing santa. We
I have the same problem. Ever find an answer?
Posted on Nov 28, 2011
I have a 5 foot singing Grinch that I cannot get into the standing position. I have pushed down on his shoulders and releasing gently. I've searched for a dial on Neck to turn and cannot locate
I have a 5' Singing Dancing Skeleton by Gemmy Industries
ebookss.holding.no-ip.ca/F/support/t6410955-5_singing
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
15235022 Penguin won't dance - Document Download
codigo.no-ip.net/F/support/t15235022-penguin_won_39_t_dance
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
I have a lifesize grinch who stole christmas(Gemmy 5 ft - Fixya
Dec 01, 2015 | Toys
My gemmy dancing/singing Santa only speaks Spanish how do I switch it to English?
It can't. It has built in spanish. Should have bought the English version.
Nov 13, 2014 | Gemmy Life-Sized Animated Santa
Can you buy the power cord for the gemmy santa clause
Any the adapter plug is identical to a rechargeable drill and the volts for it are 9V hope his helps
Jun 17, 2014 | Gemmy Life-Sized Animated Santa
Santa moves and mouth moves but no sound.
Hi there my Santa sound is coming on real low then goes off
Nov 18, 2013 | Gemmy Life-Sized Animated Santa
I need an instruction manual for gemmy lifesize singing and dancing santa
The shoulder thing worked! thanks so much!! i was all over that thing!
Dec 10, 2012 | Gemmy Life-Sized Animated Santa
Dec 13, 2010 | Gemmy Life-Sized Animated Santa
Toys Logo
718 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
