Question about Sceptre 17" LCD Monitor
Need power supply for a lcd sceptre x7g - Sceptre 17" LCD Monitor
So far only option I have found would be purchasing a used one or broken one off sites such as ebay and swapping the part. make sure if it is a broken one the damage is only for a problem like a cracked screen.
Posted on Dec 26, 2009
  • 81 Answers
Try www.newegg.com or google search for it, sry thats the best i can think of!
Posted on Dec 11, 2009
Sceptre X7G komodo II Power light and screen flash about every second. Could it be the blanking circuit?
Look for bad caps with domed tops as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/SCEPTRE/Sceptre%20X7G/
should repalce the caps in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 24, 2011 | Sceptre X7G Komodo II 17 in. Flat Panel...
Sceptre Monitor P/N X7G-Komodo II displays for about 1 second at a time, then goes black. When I cycle monitor power, I see a perfect display for 1 second. Does anyone have a recommended solution?
When the backlight does not stay on for more than a second, the problem is usually the backlight power supply board failure. Typical failures are blown capacitors, or transistors. A electronic repair shop should be able to fix it.
Oct 05, 2010 | Sceptre X7G Komodo II 17 in. Flat Panel...
X7 G-NAGA VI POWER SUPPLY Transistors
do an advanced search on ebay for seller techtronsaver he should be able to supply you with the parts you need
Jun 04, 2010 | Sceptre 17" LCD Monitor
My Scepter LCD Monitor just blinks when it's turned on
Open it up and the first place to look will be the power supply section, look for bad caps with bulging top/bottomseal, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 12, 2010 | Sceptre X7G-Agama II (Black) 17 in. Flat...
Spectre x7, at startup, screen blinks on and off. blue light at bottom also goes on and off
leos343872, Black screen type of failure. Is anything still displayed even though screen is black when you hold flashlight 1 inch from lower left corner near start button??? Possible "switch-mode-power-supply" in shutdown mode. Tech or you will need to evaluate further!! Read more of my advice to other owners with BLACK screen monitor problems in my profile. or louie12fix profile. 12fixlouie
Dec 14, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Sceptre X7G Naga VI dissaembly.
I have a bad power supply in mine as well. trick to opening it was popping off the silver caps on the base to remove the base. then using 2 bladed screwdrivers carefully pry the front plastic bezel off the back. there is no glue just locking tabs.
Dec 04, 2009 | Sceptre 17" LCD Monitor
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
Sceptre X7G-Naga VI
My problem sounds equivelant: The problem is that it will power down after 15 minutes, then take 1/2 hour or more to power back up!I believe I have solved my problem with my X7G! I remember seeing a direction on the only direction papaer I got with it that told me to Turn off ALL POWER SAVING WINDOWS SETTINGS! I think the monitor is set to care for all the monitor/power saving itself. I am going to try it and will get back to you, or just try it yourselfs!
CWD
Dec 22, 2008 | Sceptre 17" LCD Monitor
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
Sceptre 17" LCD Monitor Logo
109 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
