Administrator Password needed for Riso SC7950
I need to log into my SC7950 so I can change the IP address but it's requiring me to enter a password. I need to find out what the default password for an Administrator is.
  • 622 Answers
Try 123456 or 123456789 if its a kyocera then 6482
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 12, 2009
I need to log into RISO 9150/7150 so I can change the IP address but it's requiring me to enter a password. I need to find out what the default password for an Administrator is.
no entry for password leave it blank and press ok
https://www.manualslib.com/manual/1102583/Riso-9150.html?page=11#manual
Dangerous !
Initialize (only on the operation panel) Clears the administrator settings and deletes the user information, and returns all settings to their default. • Delete all user information: Deletes all user information registered with user setting and all personal folder. • Clear Admin settings: Returns all administrator settings other than user information to the factory settings. When the machine has been initialized, the information (data) cannot be restored, so make sure you want to proceed with the initialization procedure.
May 25, 2018 | The Computers & Internet
How do a forgotten admin password on a xerox 7655
WorkCentre 7655 7665 7675 Online Support Solution Modify the Printer...
Solution : Modify the Printer's Administrator Password Using CentreWare Internet Services (CWIS) NOTE: This solution assumes the WorkCentre is configured and working properly on the network.
  1. From the computer, open an Internet browser window.
  2. Enter the IP address for the WorkCentre in theAddressfield, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Properties] tab.
    NOTE:If the Login screen is displayed, enter the user name in theUser IDfield, and the password in thePasswordfield, and then click on the [Login] button.
    The default username is "admin" (case sensitive), and the default password is "1111". If it has been changed or forgotten, contact Support.
  4. Click on [Security] to expand the list of options.
  5. Select [Authentication Configuration].
  6. Click on the [Modify] button for Device System Administrator Password.
  7. Enter a new password in theNew Passwordfield.
  8. Retype the password in theRetype Passwordfield.
  9. Click on [Save]. This will be the new password to log into the Control Panel and CWIS.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=143,E=0000000004704152929,K=9646,Sxi=4,Case=obj(3814)
Solution : Modify the Default Admin (Tools Mode) Password on the WorkCentre NOTE:The Admin (Tools Mode) password allows access to configure network and machine settings on the printer.Xerox recommends only changing the default Admin (Tools Mode) password if absolutely necessary. If the password has been changed from the default password (1111) and has been forgotten, a service call is required to reset the password.
To change the default Admin (Tools Mode) password:
  1. Press the [Log In / Out] button on the Control Panel. The Log In window will be displayed. See theRelated Itemsbelow for additional information regarding logging into the WorkCentre.
  2. Select [Security Settings] on the left side of the screen.
  3. Select [Authentication] from theGroupscolumn and then select [User / Administrator Accounts] from theFeaturescolumn. The User Administrator screen will be displayed.
  4. Select the [Account #] field, and then select account number 1 using the keypad on the Control Panel.
  5. Select the [Configure Account] button. The Configure User Accounts screen will be displayed.
  6. Press the [Clear C] button (several times, as required) on the Control Panel to clear the old password.
  7. Enter the new password using the keypad on the Control Panel.
  8. If necessary, place a check mark in the [System Administrator (Admin)] and [Account Administrator] check boxes, and then select [Save Account].
  9. Select [Close].
  10. Press the [Log In / Out] button on the Control Panel.
  11. Select [Logout] on the Touch Screen.
Apr 04, 2014 | Xerox WorkCentre M-24 Color Copier
Assign ip address
Which operating system and type of router ?
Use dos comand
The administrator account on a Windows machine is the main, root user name that gives full access to the machine.
Administrators should change this password frequently to avoid unauthorized access to the domain or desktop machine.
This can be done in the Windows Control Panel, or use the "net user" command in the Windows DOS prompt.
Log in to the machine using the administrator username and password.
You can also use an account that has administrator privileges on the domain or desktop computer.
Click the Windows "Start" button and select "Run" or "Start Search" (depending on your version of Windows).
In the text box displayed, enter "cmd" and press the "OK" button.
This opens the command prompt window.
Type "net user administrator <new password>" into the command prompt.
Replace "<new password>" with the password you want to set.
Enter the password again for confirmation.
Once you enter it again, the administrator password has been changed.
Test the new password by rebooting the machine and logging in with the new administrator password.
Nov 29, 2013 | Computers & Internet
Cant login on my login name and password
You may need to reset the password. You can do this by locating the IP adderss for your router, then input it in two the search bar at the top of your browser (note: you have to have a wired connection the the router for this to work) log on with user id: admin or admin1 or administrator and for the password enter: admin or password .. enter system settings for the router to change your personal user password. If you have a problem with locating the IP address for your router contact the maker or try serching the internet, that part should not be too dificult; all manufactures use the same IP address.
Oct 22, 2013 | Computers & Internet
I could access the router log in page and then go to the status page but I cannot go to the advanced setup page. I would like to know the setup page address that should be like...
For user access enter the default user password user to view the status only. The
following window will appear.
Administrator Access
1 For administrator access enter the default admin password 1234 to configure the wizards
and the advanced features.
2 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
3 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
confirm and click Apply. Alternatively click Ignore to proceed to the main menu if you
do not want to change the password now.
This router has a user password to see the status and an administrator password to change settings. Please mark this as solved if this solves your problem. If not feel free to ask more questions :).
Mar 02, 2011 | Zyxel P660HW-D1 Router
Need to change my password how do i do that?
Welcome to Fixya. If you want Password on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure.
Thanks for using Fixya.
Feb 14, 2011 | NetGear WGT624 Wireless Router
Wish to log on to router
In order to log onto the router, you will need the router's password (not the wep/wpa passkey, but the other password). You will also need a computer that is connected to the router (does not matter if its wireless or not). First, you will need to know that router's IP Address. To find this, open a command prompt window on your computer, and type in the command "ipconfig", and hit enter. Your router's IP will be shown as the default gateway. Next, open up a web browser, and, in the address bar, type in the router's IP address. A login window will pop up, requesting a username, and password. Depending on the router, and whether or not it has its default settings, these are some of the possible combinations:
  • Username: admin, <blank>, administrator, comcast, or even password (these might not be all of them, they are just common ones)
  • Password: <blank>, 1234, admin, password, default
Once you successfully enter the username and password, you are logged into the router.
Mar 01, 2010 | Computers & Internet
How do I add a new user to scanfront220p
Best advice is to access the web menu on the device and log in as the administrator.
Firstly, the network scanner needs an IP Address in order to access the web menu. You will need to log in as an administrator to change the IP address settings on the device.
I found that the default "administrator mode" password was just blank - no password whatsoever.
Sit down at the scanner and click the administrative mode or administrator button at the login screen. You should be prompted for the password.
If you have a router that uses DHCP then be certain that the device is configured for use with DHCP. Otherwise, configure a static IP address on it that is within the IP range of the network it is connected to.
Once you have either discovered the IP address of the scanner or assigned one manually you will want to go to another computer on the same network.
To access the web menu you will need to go to the IP address of the device - I.E. if the scanner has an ip address of 192.168.0.2 type in:
192.168.0.2
into a web browser (as though you were typing in http://www.google.com - ONLY type in the numbers and periods). The web browser needs to be on a computer that is on the same network or connected directly to the scanner via an ethernet cable and have an IP address set statically on its network card. I would google "Setting a static IP Address" and the name of your OS.
From there you will see a "To Administrator Mode" link in the upper right hand corner of the Web Menu screen. Click on that and authenticate with the same administrator password that was used earlier.
You should be able manage user accounts from within the administrative web menu!
Feb 11, 2010 | Canon ScanFront 220P Flatbed Scanner
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
Scanning
Follow the instructions below if you run into any configuration problems report back to this site and I will be notified by email.
Scan to E-mail allows a scanned document to be distributed to one or more e-mail addresses. This feature allows e-mails to be sent from the printer directly to an SMTP mail server.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution, as it requires knowledge of the network’s email system.
The printer will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address). Before you begin, print a System Settings List and make sure the printer has an IP Address and that Internet Services is enabled. See the Related Items below for additional information.
NOTE: An e-mail server must be configured properly and running on the network to perform this solution. The IP Address of the e-mail server is required.
  1. Open an Internet browser window on the workstation.
  2. Enter the IP Address of the printer in the Address field, and then press [Enter] on the keyboard. The Internet Services window will be displayed.
  3. Click on [Properties]. The Properties window will be displayed.
  4. Click on [Machine Details] from the list on the left side of the window.
  5. Enter a valid SMTP Compliant e-mail address in the Administrator E-mail Address field.
    NOTE: When entering the address the SMTP-compliant format must be used, for example, person@company.com. Any replies to e-mail sent from the printer will go to the address specified in the field.
  6. Enter a valid SMTP Compliant e-mail address in the Machine E-mail Address field.
  7. Click on [Apply New Settings].
  8. If prompted for a user ID and password, enter the administrator user ID and password in the fields provided, and then click [OK].
    NOTE: The default user ID and password is admin and are case sensitive.
  9. Click on the [+] next to the Protocol Settings folder. A list of items will be displayed.
  10. Click on the [E-mail] link. A list of settings will be displayed on the right side of the window.
  11. Select the receiving protocol to be used from the Receiving Protocol pull-down menu.
    NOTE: Contact your System Administrator for more information regarding the receiving protocol of your e-mail server.
  12. Enter the IP Address of the POP3 Server in the POP3 Server Address field.
    NOTE: There is no option to set a DNS Host Name for the POP3 Server. Contact your System Administrator if you require additional information.
  13. Enter the username for the POP3 account in the POP User Name field.
  14. Enter the password for the POP3 user name in the POP User Password field.
  15. Enter the password again for the POP3 user name in the Confirm Password field.
  16. Enter the IP Address of the SMTP Server in the SMTP Server Address field.
    NOTE: There is no option to set a DNS Host Name for the SMTP Server. Contact your System Administrator if you require additional information.
  17. Click on [Apply New Settings]. A page will be displayed asking for the printer to be rebooted for the new settings to take effect.
  18. Click on [Reboot]. A 'Do you want to Reboot?' message will be displayed.
  19. Click [OK] to continue with the reboot.
  20. Click on the [X] in the upper, right corner to close the window.
Jun 20, 2008 | Xerox WorkCentre M-24 Color Copier
3,902 people viewed this question
k24674
Marvin
Marvin
