Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
Got a Line 6 Spider III HD 75 at the flea market.
Found a Line 6 Spider III HD 75 at the flea market. One problem; can't get it to come on. I think maybe it's a fuse problem, but can't find the fuse panel. Anyone know where it is? This is a head from a combo unit.
THANKS
JW
  • 140 Answers
The unit has internal fuses. You have to take it apart. If the fuse is blown you more than likley need some service. You can call Pro Line Music 215-736-8055
Posted on Dec 11, 2009
SOURCE:
I have a line 6 spider jam ...was playing guitar and then the sound went dead... loops work lights work but no sound
It probably the output Ic named TDA7293 and maybe because of the fan malfunction, let me know a bit further to help you more.
Oct 22, 2013 | Line 6 Spider Iii 75 Guitar Combo...
Do you have the user manual
You can download the Line 6 Spider III 75 user manual here http://line6.com/legacy/spideriii75
Oct 17, 2012 | Line 6 Spider Iii 75 Guitar Combo...
My line 6 spider 3 75W amp will not show any lights when I turn it on nor make a sound. Only the backlight on the display will turn on and be blank. I have tried the factory reset and it still will not...
Probably the 3.3 volt power that supplies the DSP has failed or is being shorted out. If you are not electronicaally adept, best to take it to a shop for repair.
Jan 02, 2011 | Line 6 Spider Iii 75 Guitar Combo...
How do you reset your line 6 spider jam?
Hold down the settings/tone button as you turn on the power and keep holding it for 5 to 8 seconds. Here is a link you might like:http://line6.com/community/docs/DOC-4629
Aug 21, 2010 | Line 6 Spider Iii 75 Guitar Combo...
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
En los amplificadores Line 6 Spider III ¿puedo conectar pedales de efectos que no sean de la misma marca línea 6?
translation: In the amplifier Line 6 Spider 3, is it possible to connect effect pedals of other makes apart from Line 6.
Creo si, pero primo del amplificador con una corda guitarra.
I think that you can, just add them to the input
Jan 23, 2010 | Line 6 Spider Iii 30
Line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
453 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Joaquim Martins
Are you a Line 6 Music Expert? Answer questions, earn points and help others
