Question about Compaq Presario X6000 Notebook
No screen on starting laptop
When starting the laptop there is screen, no light just a black display.
  • 1 more comment
  • rastatab Jan 21, 2008
    Have done all the usual pull out and replace, the hard disk works in another laptop, tried using an external monitor but still not even a BIOS screen, may be a problem in the graphics part of the motherboard?, anybody with directions on how to check and repair? ...with thanks
  • rastatab Jan 29, 2008
    Well I pulled the laptop apart as much as I could and cleaned the inner memory module contacts, then had a look at the connection from the motherboard to the screen it popped out without any resistance like you would expect from muti array type plugs, pushed it back into place, reasembled the laptop and switched it on, everything worked as normal,
    conclude that someone else has had the laptop apart before it got to me for repair. BIG thanks to all, I don't charge money and only help disadvantaged people with computer problems.
  • cma_verma Jul 16, 2008
    As soon as i switch my pc on,nothing appears, only black screen.
    and now that black screen has also dissappeared and there is no activity in my laptop.
    My Laptops model no is : Compaq M2000
Having the same issue. Went through the same sequence that you took. Try removing the second memory module. Mine boots with the first module populated but not both. Root cause: suspect over heating.
Posted on Jan 29, 2008
    Sergeant:
    Champion:
  • 244 Answers
Try to re-seat the memory, the memory might loose
Posted on Jan 21, 2008
What caused a black screen
I had the same problem. While rebooting the laptop the screen would be on for a few seconds after it finished rebooting then the display would go black. If you looked very carefully at the screen you could see the image was there but there was no light behind the screen to make the image visible.
I removed the black plastic display bezel cover that goes around the edge of the display screen to check out the lights and wiring. I found a small magnet that belongs inside the display bezel had fallen out of it's slot in the plastic bezel and was stuck to the inverter pcb (printed cicuit board). To fix this problem I secured the magnet into it's slot inside the display bezel with a bit of glue. After fixing the problem and putting the display bezel back together the laptop worked normally.
The magnet could possibly fall out if the laptop was closed and upside down then dropped on a hard surface. Mine did not feel very secure in the mounting slot which is why I secured it with glue.
This magnet is how the laptop knows the lid is closed. When the laptop is closed the magnet is moved closer to a magnetic switch on the inverter pcb and activates the switch. The laptop thinks it is closed and shuts off the lights behind the display screen. When the magnet fell out of it's slot and stuck to the inverter it activated the magnetic switch all the time whether the laptop was open or closed. This caused the laptop to think it was closed and shut off the lights behind the dispaly screen as soon as the reboot finished.
Aug 28, 2014 | Acer Aspire Computers & Internet
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario cq61 display not show
Aug 11, 2012 | Compaq Presario CQ61-310US Laptop
My toshiba satellite l455-s5008 screen display is black
it could be many problems first check if when you start up the laptop the hard drive runs it cuold be the screen of the laptop otherwise it has to be a problem with the mother board or the prossesor
Jan 24, 2012 | Toshiba Computers & Internet
The screen is going black like its in sleep mode when i open it up
Jul 17, 2011 | Compaq Presario CQ61-310US Laptop
Whom do i love
I have a Toshiba a505-s6020 laptop and my laptop displays a black screen with nothing else on screen but the keyboard is lights up, and only light shows the power not the hard drive, or the internet, or any of the four lights it normally has displayed on the side. Can you fix my black screen of death issue?
Jun 18, 2011 | Computers & Internet
Black Screen
possibly ur display chip or graphic chip faulty. repair it from laptop repair prof.
Jun 25, 2010 | Toshiba Satellite A205-S5804 Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Hp dv5000 Screen blacks out
sounds like the backlight is going out do me a favor turn it on and put a light source next to the screen if you can see everything on your screen then its the backlight
Mar 10, 2009 | HP Pavillion ZV6000 Notebook
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Compaq Presario X6000 Notebook Logo
109 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
