Question about Compaq Armada E500 Notebook
Where is the hidden screw located so I can remove the keyboard from a Compaq Armada Edoo to allow for extra ram to be inserted? Thanks
  • 2,229 Answers
Normally in laptops, there "might" be one screw under the computer about in the middle of the keyboard. It is normally not hidden anywhere. If there is a little compartment with a cover under the computer, you might remove that and see if there is a screw there.
Otherwise, the keyboard is either held in place by clips or, alternatively, it has screws in the top under the plastic bezel that is on top of the computer just below the screen. You'll have to look carefully at the palm rest to see if there is a separate piece that lifts up to expose the top of the keyboard.
Posted on Dec 11, 2009
Keyboard Remove
Remove the 3 Phillips screws that secure the keyboard to the computer.
Turn the computer right-side up, and then open the display as far as possible.
Turn the computer upside down, and locate the keyboard release access on the bottom of the computer, inside the battery bay.
Insert a flexible tool into the opening, and then press inward to release the keyboard.
Turn the computer right-side up, and then lift up on the top and left edges (1) of the keyboard until the keyboard releases completely.
Component replacement procedures 416. Slide the keyboard back until its top edge rests on the display assembly .
Release the zero insertion force connector to which the keyboard cable is attached.
Disconnect the cable and then remove the keyboard.
Oct 17, 2013 | Computers & Internet
How do add ram or is it even possible on this unit
Hello, yes it's possible. There are 2 memory slots under the keyboard. Take a look at
http://www.ehow.com/how_6234021_install-memory-compaq-armada-e500.html
for quite a lot of info on the Armada E500. Also youtube for some useful info. if you type 'Compaq Armada E500' into the search box.
Regards
nicam49
Oct 30, 2010 | Compaq Armada E500 Notebook
How can i get to both memory slots so i can upgrade to 2GB of Ram? Thanks
Your laptop has two memory slots. One of the memory slots (external) can be easily accessed if you remove the cover on the bottom of the laptop.
The second (internal) memory slot is located under the keyboard.
Keyboard removal procedure:
1. Unplug the AC adapter and remove the battery.
2. Remove two screws securing the keyboard on the bottom of the laptop. These screws are marked with a small keyboard symbol.
3. Release 4 keyboard retention tabs located on the left side from f1, f5, f9 and delete keys.
4. Lift up the keyboard and place it upside down on the palm rest.
5. Unlock the keyboard cable connector on the motherboard.
6. Remove and replace the keyboard.
Hope this helps. Thank you for using FixYa.
Sep 30, 2010 | HP Compaq nx8220 Notebook
How to replace/upgrade RAM on HP/Compaq nx5000 laptop? HP's quick reference guide says the slots are under the keyboard deck? How do I get there? Thanks
to remove the keyboard u will 1st need to undo the screws that hold it to the board should be the 2 or poss 4 directly unde the corners of keyboard other than that the covering panel at top of laptop will need removed 1 screw either side underneath screen hinges and poss few small 1s where battery slots in once cover removed the keyboard will be held on with 2 screws at top and the cable remove both and viola
Jan 16, 2010 | HP Compaq nx5000 Notebook
I cannot open my compaq evo d51s, any ideas?
if you look at the back of the workstation you will find a hidden screw next to the air vents, locate and unscrew, the casing should slide back away from the front and lift off to access the optial drive and ram
Apr 27, 2009 | Compaq Evo D500 PC Desktop
I need to replace the keyboard on a compaq c300
As per the service manual available here on the HP Website is only necessary to remove the switch cover to access the keyboard screws. The switch cover is secured by to screws located in the battery compartment. The keyboard screws are located on the top of the system under the switch cover.
Jan 10, 2009 | Compaq Keyboard
I have compaq laptop Armada E500 and I want to upgrade my laptops ram And i dont found memory slot
Ok this laptop only takes SDram
The location of the ram is under the keyboard
Here's the instructions on how to get to it.
First shut down the laptop and disconnect any cables or whatever that is connected to it.
Then turn the computer over there is a security screw there remove that by turning counter clockwise.
Then take a paper clip and put it into the 4 keyboard releases which should be
1. right of the ESC key
2. between the F4 and F5 key
3.between the F8 and F9 key
4. right of the F12 key
Now you can lift the keyboard by tilting it up closest to the LCD towards you.
You will see a empty memmory slot which should be 1.
Put it in at a 45 degree angle and push down gently till it snaps in place.
Now you just reverse the way you took it apart and you should be all set
Happy Holidays
Dec 18, 2008 | Compaq Armada E500 Notebook
How to install ram on a compaq armada e 500
Lindie_c
Hi, a lot of these older laptops had their memory installed below the keyboard as is true for yours.
If you download this manual it will show you how to lift the keyboard and install additional memory.
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01124713/c01124713.pdf
Regards
ElApe
Sep 26, 2008 | Compaq Armada E500 Notebook
Ram change, how?
remove the cover (with buttons) above the keyboard by gently prizing it off with a small screwdriver at either end.
lift the keyboard off and the ram is hidden under a silver plate held in place with two small screws.
Dec 12, 2007 | Compaq Presario Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
