Question about Car Audio & Video
When i press the brake the blinkers light up and when i use blinkers they all come on in my 03 folcon , thanks
  • 2 more comments
  • wethinkuniqu Dec 11, 2009
    hi ,would the blinker switch be the problem if the brake is pressed and the blinkers come on and stay on with brake light
    hi when i push the brake pedal all the blinkers come on and stay on with brake , and when i use blinkers they all come on like hazard lights,ive disconected brake switch and its still doing it ,thanks brett
    sorry , 03 model falcon
    ive just disconected the blinkers and the brake light are still turning on all the blinkers and when i disconect the brake switch the blinkers are still flashing like hazards ,i havnt replaced any globes or touched anything just drove in my drivway and the dash blinker lights came on when i used brake to stop , thanks brett
    Top Expert:
  • Car Audio & ... Master
  • 79,865 Answers
Make and model and year of Vehicle please.
Posted on Dec 11, 2009
  • 1 more comment
  • yadayada
    yadayada Dec 11, 2009
    sorry see the year there, this is in most cases caused by a defective turn signal switch in most cases, remove the steering column covers and disconnect the turn signal switch, if the problem goes away replace the turn signal switch.
  • yadayada
    I didn't say to disconnect brake light switch, disconnect turn signal switch.
  • yadayada
    One other question, u haven't by chance put brake light bulbs or turn signal bulbs in this have u??
    President:
  • 1,615 Answers
Just so I get you right, what are we woring on here
03 Durango- rear tail lights. All new bulbs. New housing. Reverse light doesn't work, blinker flashes fast when brakes applied (normal with brake not applied), with headlights on brake lamp only lights...
No, your brake lamps should only work when brake pedal is activated. Your headlamp switch shouldn't have anything to do with brake lites.
Sometimes if there is a faulty ground, your lamps may act weird?
Did I miss-understand your post?
Feb 27, 2018 | 2003 Dodge Durango
Signal lights on dashboard
I would start at the left brake light. Check the bulb and wiring. Your brake light could be grounding through the blinker circuit.
May 13, 2013 | 2000 Chevrolet Venture
I have a 1990 Chevy Suburban v1500. All lights work except for the Brake Lights and Turn Signals. The Blinker switch on steering column is broken, other than that everything is fine.
Yes, the brake light signal on American cars is routed through the turn signal switch. A new switch should restore both your turns and your brake lights.
American cars use the same bulb filament and same wire to the rears for both brakes and turns. Press the brakes when turning and both rear brakes will light, but since one side travels through the flasher relay, that side will blink, while the other side has a steady light.
Apr 06, 2013 | 1990 Chevrolet Suburban
I have a 1990 Mercury Cougar. Several problems...Blinkers, hazards, horn, and break lights are not working. However the break light in the back window comes on when the break is pressed. Checked fused and...
I am unaware of what a "CO" display is.
Now with the blinkers, hazard, horn and brake lights not working that may be the multi funtion switch (blinker switch) that is located inside the column (where the blinker lever attaches).
Obviously the blinker, hazard and horn will all work off of something in the column. Brake lights, you may think a switch on the pedal.
the brake lights do work with that switch but when you have the kind of tail lights where a turn signal light shares the same bulb as a brake light, the brake light is cancelled for the turn signal by running through the multi function switch inside the column.
The third brake light does not blink so its not on that same circuit.
Oct 07, 2011 | 1990 Mercury Cougar
2001 ford f150. blinkers want work. brake lights want work. but the light at rear above back glass works when i press the brakes. help
you need first to determine the obvious as most people don't check to see if there brake lights work. make sure the bulbs are not burnt out. if you use the blinkers and the light stays on when you operate them that is usually an indication a light is burnt out.
Aug 16, 2010 | Ford F-150 Cars & Trucks
Brake lights not working
the brake pedal has a brake light switch mounted on the same bracket. Replace that switch
Mar 28, 2010 | 1989 Buick Regal
Running,blinkers,brake lights 66 Impala
Hello, the hazzard flasher is causing the problem . Gm had issues with the flasher relay. Please rate my answer thank you.
Apr 06, 2009 | Chevrolet Impala Cars & Trucks
1984 F-150 Brake Lights and Blinkers
on the brake peddle there is a switch when you press the brake peddle..check to see if after you press the peddle it should activate..it could be stuck or out of place...you may need to get a new one..
the blinker you will have to purchase a blinker relay...ask any part store for it...
Feb 16, 2009 | 1984 Ford F 150
Pressing brake causing blinker issue
The trailer harness that was installed probably has a short inside the box that distributes power to the trailer pig-tail. Remove the trailer harness. You problem will be cured.
Jan 27, 2009 | 1999 Toyota 4Runner
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
