Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
Cell phone made sizzling noise got hot and shut down. after two hrs phone was working, but battery wont hold charge.
    Scholar:
  • 85 Answers
Take the battery out and feel both sides with your finger. There is probably a noticeable bump. It sounds like one of the battery cells "shorted" which would explain the temporary heating and now the lack of battery life. Plan on replacing the battery (with a Motorola battery, not an aftermarket battery) and make sure that you are using a Motorola charger. The phone should be as good as new! Randy
Posted on Dec 11, 2009
    President:
  • 1,335 Answers
Your battery has essentially burned out. You need to get a new battery. You can order a new battery online from a variety of vendors. The cost should be between $10-$30 plus S&H. The price depends upon the power storage capability.(600mAh -1300mAh) The higher rating gives you more talk time. Check out batteries4less.com.
My iphone 5c stopped working suddenly, its screen darkened and it does not work. What is the problem?
Reset the phone:
  • Plug the charger into the phone.
  • Hold down the Home button while holding down the On/Off button.
  • Continue holding these down until (hopefully) the Apple displays on the screen.
Mar 08, 2015 | iPhone 5c Cell Phones
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
My phone keeps shutting on and off and wont charge when plugged in
Cell phone batteries have what is called a "memory" over time if they are charged without being fully drained they can start to not hold a charge. Unfortunetly the only fix for an issue like yours is to purchase a new battery. Your local retailer / service provider should have batteries in stock or they can order one for you.
It is recommended to allow the batteries to drain completely before charging, then allow at least 8 hours or more to fully charge. Most cell phone will show a full charge after a few hours, but this is more a fault with the software that check the batteries charge, then an actual indication of the battery being fully charged.
Dec 28, 2013 | Samsung Galaxy Admire 4G MetroPCS
Stuck on start up screen, will not go to home screen
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 03, 2012 | Virgin Mobile - Lg Optimus Elite Mobile...
I HAD MY NOKIA E5 SHUT DOWN SUDDENLY. AFTER CHARGING IT FOR HRS IT DOES NOT START. PLS LET ME KNOW WHAT SHALL I DO
check your battery voltage by a multimeter (DC under 20) under 3.7 can't turn phone on
Aug 07, 2011 | Nokia E5 Cell Phone
My iphone will not charge or power up. I have the battery showing on screen with the red and the "bolt" icon showing that it is charging. I have been charging for 24 hrs and it will not charge or power on....
Hi, you have got bad cells in your battery and this is preventing it from holding any charge all you need to do is get the battery replaced and this will solve your problem, this is a common problem and usually happens if the battery or phone has got hot, but replacing the battery will solve your problem.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page on unrated posts, thanks
Aug 27, 2010 | Cell Phones
Battery only holds charge on standby for maximum of 36 hrs
Try running the battery down to totally empty before you charge it. It may retain the charge longer
Aug 14, 2010 | Samsung Cell Phones
P168 - shut down
try wiping off the connections n hold button down for a min.
Oct 17, 2008 | Dual Electronics CECT P168 Cellular Phone
Please Help !!! my Motorola RAZR V3i is automatically shutting down ...
take the phone and have the firmware reflash this should correct the issue that you are having
Jun 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Sidekick 3 has black box in middle of screen but wont shut on!!
gets stuck on the key-jump.gif symbol? Do a soft reset @ + 1 + 0 and hold down the W or you can pull the battery out and place it back in while holding the W and see what happens when you startup while holding W. __________________
credit: Sweet Peaches vbmenu_register("postmenu_999614", true); http://www.poweredbydanger.com/forums/showthread.php?t=97974
Nov 08, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
168 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
