Question about TurboChef TORNADO Electric Oven
I have NGC tornado Turbochef, it is toasting too
I have NGC high speed tornado Turbochef, made for Subway stores, it is toasting too dark? Any suggestion? I can change setting, high temprature is set to 1000F
    Scholar:
  • 75 Answers
The subway ovens are supposed to be around 1000 dont change any of the settings if you think you are having programming issues speak to your field rep and ask them to reprogram your oven. they have a smart card for doing this. it will give you all the latest buttons including hashbrowns and breakfast stuff.
most common problem with toasting to dark is that you are using the wrong buttons
try cooking the next sandwich on the 1meat hotwell setting and select the sandwich size. you will notice the sandwich cooks much lighter.
if you cook using the combo subs button this could be your problem. most of the time re-training is just needed
Posted on Jan 28, 2010
    Problem Solver:
  • 14 Answers
Temp should only be no higher than 500 try that
Posted on Dec 12, 2009
IR Temperature will not rise, checked I/O Board, K4 K5 relay and High limit switch. Any other suggestions, I am down to the IR element itself.
Posted on Sep 01, 2010
    Problem Solver:
  • 10 Answers
Mckennasub is correct except some stores depending on the humidity level and other variances might havet o adjust the idle temp. reduce by 50-100 degrees at a time and see if that helps. The smart card field reps have only bring the oven to current subway settings. you an still reduce temp if oven is toasting to much.
Posted on Apr 17, 2010
Oven showing door close error with _ _ M
there are little switches inside that the door hits when you close it. open both side panels then open and close the door. you'll see them in the upper left. there primary, secondary, and monitor. PSM. they either broke or something need adjusted. easy and cheap fix. you could take the leads off and jump them until you get switches. but they are a safety feature so do at your own risk.
Jul 12, 2015 | TurboChef TORNADO Electric Oven
I bought my turbochef NGCEW ex Subway. It heats up no problem and then shows the Subway menus but I can't seem to access the edit menu. Also, some of the keys don't beep when I press
This might help you out:
http://www.basequipment.com/v/service/TurboChef/NGC.pdf
It's a service manual for the TurboChef NGC Tornado.
Pay particular attention to pages 15 through 19. It shows you how to edit menus and to reset everything.
Oct 21, 2014 | TurboChef TORNADO Electric Oven
We have Turbochef NGC N6. The units high limit thermostat had tripped. Re-set thermostat and found cooling fan not working. also found thermal cut out ( top left rear looking from above ) had also tri
ur high limit trip because ur heater overshoots the program setting for the temp replace ur k4/k5 solid state relay for it controls ur temp for the heater.
Sep 21, 2014 | TurboChef TORNADO Electric Oven
How do I get a NGC technical service manual?
kit-supplies.com/images/downloads/NGC.pdf please rate my work thanks
Feb 17, 2011 | TurboChef TORNADO Electric Oven
I am working on an NGC subway oven and the store manager told me it would only heat up half way
Check the IR element. check the heaters. check the high limit switch on the back of the oven. Usually the IR element will have burned wires where it enters the oven and will need replacing.
Oct 06, 2010 | TurboChef TORNADO Electric Oven
My turbochef tornado gives an error messag of
this is simple to fix but usually costly sorry to say.
F1 blower means the motor is not running when commanded.
first check the motor and verify if it spins freely - if the motor does not spin freeely remove the obstruction or replace the blower part# NGC-1025
just to clarify its the big blower behind the cook chamber not the little fan in the electrical compartment.
Dec 30, 2009 | TurboChef TORNADO Electric Oven
I own a subway store, we use a turbochef tornado i believe, there are a few parts that need to be replaced (i had to buy them myself, and try to replace them myself, because i cant afford to pay for...
send me an e-mail at mckennasubway@gmail.com since your a subway owner i can help you get your parts cheap. I hope your not paying retail for these parts.
easy to replace you need to take the top and right cover off. Usually you would replace the mags at this time also
Dec 11, 2009 | TurboChef C3 Single Oven
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and sandwhiches. We are planning to have pizza. Is anyway you make adjustment for Pizza
Dipending upon what kind pizza you want to use.
Subway using the same toster to Bake personal pizza (90 Second for 1 and 120 sec for 2 pizza
Oct 17, 2009 | TurboChef TORNADO Electric Oven
This is the 3rd time for this turboChef oven - door not closed.
it is because the switch kits are not setup properly.they need to set to open and shut in the right order,hope this helps regards lse
Jan 16, 2009 | TurboChef TORNADO Electric Oven
Turbochef Oven Repair
goto http://www.hobartcorp.com/default.aspxs site its hobart.Find the nearest office to you,either they will service your equipment or can lead you in the right direction.
Nov 16, 2007 | TurboChef TORNADO Electric Oven
TurboChef TORNADO Electric Oven Logo
862 people viewed this question
Top TurboChef Ovens Experts
Steve Allison
Steve Allison
Dennis Boxerman
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
