Question about Cycling
2005 schwinn missile fs scooter only runs when charger pluged in and when pluged in very weak.
  • rayrod4436 Dec 11, 2009
    thanks thats what i was thinking
    yes thanks that is what i was thinking
    Top Expert:
  • Cycling Master
  • 84,540 Answers
U are going to need to replace the battery it is worn out.
Posted on Dec 11, 2009
SOURCE:
I am looking to buy a schwinn missile fs electric scooter v for 110 dollars. He says iys like new. Should I do it?
What you should do is check the condition yourself or better have a mechanic do so, and make sure it is not stolen.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 25, 2018 | Electric Cycling
I have a Schwinn lightning fs 2.0 scooter what year is it and what batteries does it take
From Schwinn support page: "Currie Tech has licensed the Schwinn logos for use on their electric scooters. If you're looking for any type of information, parts, or service for your scooter, please visit their web site at Currie Technologies Hybrid Best Electric Bikes and Bicycles Bike" They may be able to ID the model year if that is important to you. It appears they no longer manufacture bikes under the Schwinn name, however.
But for a battery just Google "Schwinn lightning fs 2.0 battery".
Apr 10, 2018 | Schwinn Cycling
How do you charge your schwinn missel fs?
Using the charger, connect to battery and wall outlet
Jun 28, 2014 | Schwinn Missle FS
I have a Pride legend three wheeler- I replace the battery charger because it would not charge the batteries. I pluged the new charger into the control module it will charge the batteries. Batteries are...
if I understanding this correctly , you cannot use the scooter why it is being charged, there is a inhibit pin that stops the scooter from being used,
All scooters are designed this way.
Regards
Dec 14, 2012 | Pride New Mobility Legend 4 Wheel Scooter
My Schwinn S-180 scooter won't charge
Check your charger with a meter and see if it is putting out the correct voltage for your scooter battery. If it is, you probably need a battery, probably so anyway after 2 years. Good luck!
Mar 16, 2010 | Transport Schwinn Rechargeable Portable ...
Battery doesn't charge
i had the same problem so i took the battery out and pluged the moped in and it ran so i knew the battery had a prob then i took the battery out of the canvas case and it had expanded to the point were it almost leaked (exploded battery in other words)
Jul 16, 2009 | Transport Schwinn Rechargeable Portable ...
I have a schwinn missle fs and it has new batteries. i put the charger on it to charge and the charger light says it's charged but it's not. What could be the problem?
I've never worked on a Schwinn battery-powered scooter, but I'll weigh in--I'd check that the batteries are properly connected to the scooter. The charger may be connecting to the batteries, which are charged, but if the batteries aren't connecting to the motor, you're not going to go anywhere.
The only other thing I can think of to check is for blown fuses. Good luck.
Jun 18, 2009 | Electric Bicycle Motor, Bike,electric...
Does the S600 and a Missle FS schwinn scooters use same charger?
Hi you can use the charger if the Specifications match up. Output volts, Amps, Charger size, The most important is it 24 volt or 36 volt charger. Check your scooter to see what volt it runs at. Must be equal to your scooter!
Mar 03, 2009 | TitanNet PowerStar Replacement Battery for...
Cycling Logo
75 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
