Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
I have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Posted on Dec 13, 2010
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
Cl 500 wont start
check fuel pump fuel pump relay then the usual plugs have spark if no spark could be coils or immobilizer fuel getting to injectors
Mar 26, 2015 | Mercedes-Benz C-Class Cars & Trucks
1992 indy 500 efi, fuel pump will not pump when I pull the engine over, it will only pump when I turn on the key, why?
It probably pumps to bring the fuel rail up to pressure then shuts down. If you crank the engine and it is not injecting fuel the fuel rail pressure will not drop hence the pump will not start.
Mar 09, 2015 | Polaris New Genuine Polaris Snowmobile...
I reringed a polaris indy sport with a indy 500 engine in it, now the gas will shoot out of the spark plug holes. Is the fuel pump diaphram bad? Or are BOTH needels stuck? Or?????
SOUNDS LIKE THE ENGINE IS BADLY FLOODED, SHUT YOUR GASS OFF AND REMOVE THE PLUGS, THAN PULL IT OVER UNTIL IT IS UNFLOODED. IT SOUNDS LIKE THE NEEDLES ARE STUCK IN YOUR CARBS
Dec 10, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Feb 16, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1982 lincoln mk v. It wont start. I replaced the Ignition spark module and the coil . I even used starting fluid to see if the problem was fuel. But it still wont start.Please help.
Make sure it is not firing.Since you installed the ignition module,the plugs may be fouled out by fuel.If so,replace the spark plugs,and it will start.If there is no spark,the stater in the distributor will be the most likely problem.The stater is the other part that goes out,if the ignition module doesn`t.I hope this helps,let me know if I can help you any more.
Oct 25, 2009 | 1983 Lincoln Mark VI
Snowmobile
First off, you need to put this under a different product.
For another, check the battery before you ask dumb questions!
Most efi sleds use a battery. Check it.
Feb 01, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
1,733 people viewed this question
Top Polaris Winter Sports Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
