Question about Poulan Garden
Proper carb adj for ~ 20 year old Poulan model 2000 chain saw?
Carburetor adjustment
dontbother10
  • 2220 Answers
SOURCE: I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Posted on Sep 05, 2009
  • 124 Answers
SOURCE: what is the walbro chain saw carburetor adjustment for a
There is no set adjustment on any chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: 20" poulan chain saw cuts at angle
Buy an oregon green chain for the saw,much better chain, more teeth,heavier duty,outcut the original chains by far,and can be sharpened many times over.Keep the chain sharp and she should cut straight.Dont over tighten the chain, I tighten mine til I can just lift the bottom of the chain almost completely out of the bar groove.
Posted on Jan 15, 2010
  • 4088 Answers
SOURCE: Carburator adjustment for Homelite xl 12 chain saw
Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should get the engine running if it will. If it does not, check the lower diaphragm on the carburetor for hardness or cracking. You appear to be running on prime only--the carburetor doesn't seem to be pumping in fresh fuel. You may need to do a carburetor clean and re-kit. Check the fuel line condition and the fuel filter in the tank for plugging. Make sure the muffler and air cleaner are not plugged. Once you get the engine to continue running, warm the engine up. Open the throttle and adjust the H needle CW--the engine should start to speed up, but still 4-stroking. The proper setting is 4-stroking, but immediately 2-stroke when cutting. Release the throttle and adjust L needle CW so that the engine runs fairly smoothly, yet will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Posted on Apr 17, 2010
Testimonial: "Thanks for the help. A very complete answer should cover all the possibilities."
nedkelly900
  • 345 Answers
SOURCE: carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Posted on Apr 28, 2010
Trx350tm2002model, runs fine after carburetor cleaning but is dying soon as rpm is increased What adjustments can I make to carburetor since I lost the adjustment setting to the fuel intake needle valve.
The carburetor actually is a mixing place for the air and fuel. If the mixture is not in appropriate proportions this issues surfaces. Many a times as the carburetor gets old, the jet, idling valve etc., may not function properly. My suggestion would be to replace the carburetor unit itself or try adjusting the air intake valve or air filter adjustment.
Dec 20, 2017 | Motorcycles
Proper adjustment for carburetor
A proper adjustment of a carburetor can only made IF ....
The seals on the crankshaft are good , no leaking gaskets and a good clean fuel line (and no tankairiation problem) and the cillinder compression is good and also a clean airfilter on the carburetor if you adjust .
Then if thats good then only you can trust on the L + H and trottle adjustment
Echo PB 755T Operator Manual Carburetor Adjustment
Jul 19, 2016 | Echo Garden
What is the float adjustment on the carb I know how I just need the measurement on it
Search Results
    Adjusting Carburetor Float Level - YouTube
    ? 2:06
    https://www.youtube.com/watch?v=aiexehn33kg
    Oct 9, 2013 - Uploaded by Mike Nixon
    How to adjust a carburetor's float level. ... Motorcycle Mikuni CV Carburetor Cleaning for Suzuki, Honda, Yamaha Tutorial - Duration: 30:56.
    Motorcycle Carburetors ' Float Height Setting ' Fix.com
    https://www.fix.com/blog/motorcycle-carburetor-float-height-adjustment/
    Oct 17, 2014 - Learn about carburetor parts, how they work, and how to adjust thefloat height to fix your bike from running rich or lean.
Jan 11, 2016 | UM Motorcycles
How do I reset carb. screws to factory settings
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws and other two-cycle engines. ... These saws have what is called a "fixed jet" which is set from the factory. ... (7) Go back to step (5) and reset the idle speed. ... NOTE: If you do not have a tachometer, set the RPM level so that the saw "four ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
Return a type A carburetor to its factory setting by turning the "H" screwcounterclockwise until it ... Where Do I Find the Carburetor on My Stihl 017 Chainsaw?
how to adjust carbs on 2 stroke weedeaters and chainsaws ...
Dec 25, 2015 | Garden
Could some help me with factory carb settings on this saw
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Massy Ferguson carb zadith 28g Having probs adjusting the float i
Hi Michael, for more information about your question please visit the website below. Good luck and have a nice day.
How to adjust motorcycle carburetor floats
How to adjust the Float Height on Carburetor Metric Harley and Asian
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 12, 2015 | Motorcycles
1996 750 katana suzuki how to set floats?
- Now days some carburetors are produced which are fixed and no adjustment is provided.The float is made up of whole plastic like material.
Some floats have the copper/metal notch for the adjustment of fuel level.
- Take the carburetor assembly out.
- Remove the fuel bowls.
- Place the carburetor assembly with the floats upward towards yourself.
- Float level gauge and active data list (taken from the workshop manual) is required to carry out the adjustment. But you can simply adjust the float level correctly without any gauge.
- Hold the carburetor assembly at your eye level in such a way that the carburetor No. 1 is in front of you. Behind is No. 2 carburetor, then behind is No. 3 and then the No. 4. Or we can say that the carburetor No. 1 hides the carburetors 2, 3, and 4.
- Examine carefully the floats of all the individual carburetors be parallel to the surface of the carburetor where the float bowl face is seated and tightened.
- Adjust the float level by bending the float notch towards the needle valve (to decrease the float level and to raise the float) or away from the needle valve to increase the float level (to lower the float).
Apr 16, 2015 | 1996 Suzuki GSX 750 F (Katana)
How do I adjust the float switch on a pz 19
Hi, Anonymous for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to Set the Float Height on your PZ Carburetor
How to Set the Float Height on your Walbro PZ Carburetor
Float adjustment
Keihin Carb Float adjustment trick
Oct 18, 2014 | Motorcycles
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Wild thing chainsaw won't stay running. I replaced all fuel lines, primer bulb, fuel filter, gaskets to the carb. and have cleaned the carb out very well and blew out all passages. I pulled the spark...
On the carburetor got two screws to adjust the carburetor. The first is to adjust the saw when working at high speeds. Another is when running at low revs. It is best to either put back for about 1.5 cycle of the maximum of the end of the rotation of the screws. If then the saw starts, then you can adjust it fine at higher revs (H), then at low (L). Have can be minimum screw that stops the chain.
Sep 01, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
144 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
