Repair Assistance Hey Guys, I have a problem with my Toshiba Projection TV. I get sound on it but no picture. I have removed the screen to look at it and from observation of the projectors, the one on the center and the right want to light up when you turn on the TV, but the one on the left does not do anything. I have tried changing circuit boards, wires, etc., but cannot get it to work. Can you please help diagnose the problem and get back with me, please! Thank you! Lupe P.S. Email me at
  • lupeguerra Jan 20, 2008
    Slinteriors, that particular tube on the left side does not light up or heat up when the power is applied, the the other two, do light up when the power is applied and then they turn off after about a second. Could it be possible to pinpoint which drive circuitry that has the problem, because I have another used circuit board that I can use as parts. Please reply back, thank you!
    Sorry, the model number is TP48E60. I do not have the manual but you can retrieve a manual on the Toshiba website which I did to look up troubleshooting, but could not access the problem. I appreciate you help and hope this info helps you out. Thanks!
  • 8,617 Answers
You have a problem in the drive circuitry for that crt. Do the heaters in that tube light up when power is applied? What model Toshiba do you have? Let me know I will try to find out some info for you.
Posted on Jan 20, 2008
  • Sonny Berry
    Sonny Berry Jan 20, 2008
    You can pinpoint it with testing. Do you have the service manual for that set? Let me know your model number Toshiba you have. The other two are shutting down probaly going into protection mode.
  • Sonny Berry
    The manual on the toshiba site is only the user manual you will need the service manual . i will try to see if I can find one for your set.
My toshiba projection tv just started having problems. at the bottom of the screen the colors are not alignedand words and pictures are duplicated at tbe bottom of the screen
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Oct 22, 2009 | Televison & Video
Toshiba no picture
then your optical section has fault.
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
Toshiba 57h83 wont do nothing
that relay is supposed to engage power to the tv boards that control the screen.
you will have to take it to a oualified service center , because they have access to parts that are needed for repair
Oct 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
57H82 Menu does not display
My best guess is you missed a connection on the mico IC cotrolling the OSD (On screebn display)... Scour the inside, I mean pack a luch and literally look it over real good... If you find nothing take a break and start again... My money would be on that!
Jun 04, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
Mar 13, 2008 | Toshiba 50A60 50" Rear Projection...
Power light blinks and no picture
sounds like loose connections on the convergance amps ic's
Dec 15, 2007 | Toshiba 65HX81 65" Rear Projection...
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
Nov 26, 2007 | Toshiba 50A60 50" Rear Projection...
No picture or sound
hi guys! i have a tn61x81 and the probleme with this tv is when i plug the tv the tv try to open but shut down y try to push the power botom it's make no difference the light near the power botom is flashing no power no image no sound noting. i think it's the power suply but i'm not realy shure. if aneyone can help me it will be realy apreciate.
Oct 29, 2007 | Toshiba TN61X81 61" Rear Projection...
No sound or pic
Their is an IC that went out. You can get a replacement chip and repair instructions from
Nov 28, 2006 | Philips 9P5534C 55" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
