Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
My kenmore freezer 9280210 is not getting cold enough. The fan runs and frost forms on the end of the coils. The is no vacuum sound when the door is closed
  • rlauckhardt Dec 11, 2009
    I took the inside cover off to expose the coils(fins, looks like a radiator. When I pluged it in after a few minutes I saw a very slight frost on the input.
  • 4,070 Answers
If the frost only forms on the end of the coils then your freezer is low on freon. Normal freon is indicated when the coils are lightly and evenly frosted. Heavy frost on the entire surface indicates the need for defrosting and with an auto defrost system part of that system would be bad.
A qualified tech is required to find the leak and recharge the system in the case of low freon. It is not a do it yourself job.
Posted on Dec 19, 2009
    President:
  • 1,214 Answers
Please confirm whether the back of the freezer, or the coils that you said frost builds on, only have a slight amount of frost buildup. The back should NEVER have any frost, and the coils should only have a slight amount of frost. Once the coils accumulate any appreciable amount of ice buildup, the defrost system should energize. What condition are the door gaskets? This could be the problem too, and you make a good point about pulling a vacuum. Although, with leaky door gaskets, a vacuum cannot be pulled, and that puts an excessive load on the cooling system. The better test for door gaskets is to place a dollar bill between the gasket and door frame with door closed. You should feel resistance to pulling the dollar out. Door gaskets and door vacuum can be a Catch-22. You can't have one without the other, provided the cooling system and defrost system is working properly.
Posted on Dec 11, 2009
Fan not working
Generally I would check for power at the fan wiring because there are several components that can keep it from running. If the fan does have power change the motor. But if it doesn't is the coil frosted and cold enough to let the fan thermostat switch close?
Is the door switch good? Hope this helps good luck.
Aug 06, 2014 | True T19F Commercial Freezer
Not getting cold enough
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Sep 05, 2011 | Kenmore Freezers
Compressor runs bypassed thermostat with wire that turns on and off compressor,but freezer cabinet is not cold 65 degrees evaporator fan does not turn on,condensor fan on,sttill no cold
If you have just turned it on it takes awhile for the fans to come on. The evaporator coil has to get cold about (10 to 20 degrees) and make a klixion fan switch to turn the fans ON.... Is the evaporator coils getting a frost pattern on them??? If not then the system may be low of Freon.. If the coil is completely froze up and you are getting frost back to the compressor..... then you have a bad fan switch or a door switch.... If you have a wiring diagram you can trace out the wiring.... It is usually down by the compressor or control panel... hope this helps.
Mar 30, 2011 | True 23 cu. ft. / 651 liter Commercial...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
I have a True Freezer, the compressor comes on but the fans inside the box do not so there is no cold. I replaced both capacitors but still no luck.
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
Go to this web site and look in the manual on page 15. Check "Compressor runs but will not refrigerate". Gives some suggestions.
Now, inside the evap, usually strapped or clipped to the coil "U" turn on the end of the coil, is a Klixon device. This device comes in many different configurations. There may be 1 or 2 of these. One is a defrost termination switch. When evap gets hot enough so no frost is present, it terminates the defrost cycle. The other is a fan delay. It comes on when the coil temp gets to about 20 degrees. This prevents circulating warm air from defrost cycle. Now if there is only one device, it can be 2 in 1. That is, a defrost terminator/ fan delay. Will most likely have 3 wires going to it where as the 2 separate ones will only have 2 wires to each one. Now, either this fan delay is not working correctly or the coil is not getting cold enough. When it gets cold enough, it turns on the evap fans. This is most likely where your problem lays. Check it out.
Sep 08, 2009 | True 52 cu. ft. / 1472 liter Commercial...
Small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
Jun 28, 2009 | Whirlpool 25.3 cu. ft. / 716 liter Upright...
Just defrosted my freezer and is akll frosted over
When you say it is frosted over, do you mean the interior of the freezer is frosted, or the evaporator coils?
A couple things to check for:
1. Is the door gasket making a good seal when you close the door? A good quick fix for a bad seal on the gasket is to rub a thin layer of Vaseline (the original jelly kind works best) on the rubber to help it stick and to fill any scratches that might be keeping it from sealing tightly.
2. Is the fan running on the inside of the freezer? The evaporator coil in the freezer needs a fan to blow air over the coils to keep them from freezing over. They don't run continuously, and on some units will turn off when the door is open, so try holding the door switch shut when you check.
3. Is the defrost cycle working? Frost-free freezers have a defrost cycle in which a small heater turns on to thaw any frost that has begun to form. To check the functionality of the heater and the defrost timer will probably require a visit from a technician... It would take a while to explain it here, but if check the first two and come up empty handed, post back. You will need a volt/ohm meter.
I would check the first two
Mar 24, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Kenmore upright freezer not cold enough to freeze
Sounds like a door seal that isn't sealing all the way around. That would be my first replacement. Is the unit level back to front and side to side? Is it really full of food?
Call your local appliance parts house and get a magnetic door seal first. They aren't that expensive. But make sure you do not have the freezer overloaded, which could account for the lack of that vacuum sound.
Finally, is self defost? Even if it is, a lot of times the vent on the bottom in the back gets packed with ice. If it is, remove the food and use a hairdryer, being carefull to unplug the freezer first. Melt all that ice and empty your overflow tray at the bottom underneath.
Mar 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
37 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Jay Finke
Jay Finke
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
