Question about Jacuzzi Home
Hi, My on/off push button no longer works. I need to turn the jets on or off by the wall switch. Is there anything I can do? Is this dangerous? Thanks, Sandy
  • 1 more comment
  • sandstang Dec 11, 2009
    Thank you...are the jets powered by electric or gas?
    thank you !
    thank you !
  • 8,197 Answers
The push button on your tub is an air switch. The air line from the switch to the jet motor. Has a hole in it or has come disconnected. To fix the problem you need to remove the tub access panel where the motor is and look for the air line tube. It should be an 1/8 inch tube from switch to motor. Remove it and plug on end then blow in the other to see if there is a leak. If there is then replace the tube. Also make sure that it is hooked up on both ends.
Good Luck
Posted on Dec 11, 2009
  • Jyackle5
    Jyackle5 Dec 11, 2009
    Also turning on the jets with the switch is not a bad thing you will not do any damage to the tub.
  • Jyackle5
    Jets are powered by electric
SOURCE:
I have an Aqua Glass whirlpool tub, and the jets no longer work. When I hit the on/off button, it just makes a clicking sound. Do I need a new pump? If so, what type do I buy?
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
888-521-6183
US Parts Center
Nov 30, 2013 | Home
Zanussi ZKC6040
You need a new thermostat control for the oven fan. That is what determines when the temperature of the oven is low enough that the fan is no longer needed. Based on your description, the thermostat has failed in the "closed" position which means that it is always supplying power to the fan.
Nov 05, 2013 | Zanussi ZDQ495 Electric Double Oven
Craftmade Ceiling Fan Problems
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
Jun 15, 2013 | Craftmade International CXL52 Electric...
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Royal Whirlpool bathtub. After I fill the tub with water, I push the button for the jets to start and the jets only work while i am pushing the button. The button is a air button. Feels like I am...
You have a bad neumatic switch. Or a small hole in the air line. Try pushing the button fast and hard to see if it will stay on. if so , it is a hole in the tube. if not it is your neumatic switch
Mar 23, 2011 | Home
I just bought a house that was built in 2002. When I had it inspected and the first time I used it, the jets worked in the bathtub. Now they will not work at all. A little puff of air comes out of the...
yes. the air button sends a column of air down a small tube attached to the bottom of the button and the other end of the tubing is attached to the air switch in the motor.
Once you push the button, if you get a good column of air it activates the air switch in the motor and turns it on. Push it again and it turns the pump off.
If the air button bellows, located inside the button, has a hole in it then you will not get enough air pushed to the air switch to activate it. The same thing happens when trying to turn the motor off.
first thing to check is the air switch in the motor. Pull the pump and plug it into an electric outlet.
take a straw and press it on the air switch then give a good blow into the pump. If the pump comes on then the the air button on the top of the tub is bad.
If the pump will not come on then the air switch in the motor is bad and needs to be replaced.
Feb 08, 2011 | Plumbing
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
We have water in the button to turn the jets on so now they won't work. How do we get the water out?
The button is likely an "air switch" which uses a push button to send a puff of air down a tube to activate the switch at the other end. Since 99.9% of jetted tub makers no longer can use an electrical switch mounted at the surface of the tub, due to the possibility of contact with water (shock hazard).
The best way to clear the tube of any water is to remove the access panel (if you have one) on the tub, otherwise, you'll have to gain access from an adjoining room via a wall, etc. You can try to suction the wate from the tube, if you can remove the push button from the tub. I would try using a turkey baster or eye dropper to extract the water from the tube, but as I stated, the best way is to gain access to the inside of the tub components and remove the switch tube that way. It is possible that the push bulb switch has become disconnected from the actual switch mechanism and you'll need to reattach it anyway.
Check your owners manual to see where the switch is located, in case you need to get at the controls via cutting through an adjoining wall. This is why the manufacturer's all say these types of tubs should always be installed to allow access to the inside components for servicing, in case repairs are needed. Just an FYI, it is easier to repair and replace a small piece of drywall 16" by 16" than to have to repair tile work, etc. Of course, it all depends on what you're good at!
You might also want to contact Kohler to talk with one of their customer service people and see what they recommend you try. 1-800-456-4537
Hope you find this helpful and best regards!
Aug 06, 2009 | Kohler Archer 6ft Heated Whirlpool with...
How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Feb 07, 2009 | Whirlpool Home
Fisher Paykel ED56 auto sensor dryer - just not working!
It might be the circuit breaker of the mains/AC line. Pls try using another outlet/source of power. Alternately, most dryers have their own circuit breaker at the back of the unit. This would appear to be a push button switch, pls try see if your unit has one and press on it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Dryers
Home Logo
54 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
