Question about Microsoft Xbox 360 Console
When i put a game in it trys to read it than it says open tray agian
    Genius:
  • 1,093 Answers
If you are getting this it is because the sensors have burnt out on the back of the DVD drive, you need to stop the heat that is all.
To do this you can use a good Xbox 360 Repair guide or you can send it in.
Posted on Dec 11, 2009
It is an issue that most shops will say needs microsoft they will charge about £80 i have this problem and have decided its better to buy a new console only and take out the extra gaurantee.
SOURCE:
I take 7 or seven time putting the disk in and out before it reads a disk has happen since the first day i had it.
tip:read thease steps before startting
step 1:make sure there is no game in the console.
step 2:turn off your console.
step 3:take off the HDD from the top of your 360.
step 4:turn on your console.
step 5:make sure your disc tray is open.
step 6:put the HDD back on.
step 7:whilst the screen is black put game in tray and close the tray.
step 8:repeat thease steps until the game works
(it should take about 2 trys)
Jan 16, 2011 | Microsoft Xbox 360 Console
My xbox 360 keeps telling me to open tray evewrytime it trys to read my game .
The laser is dirty, or just getting weaker. The Open Tray message is a result of it timing out. I would recommend a new drive.
Mar 13, 2010 | Microsoft Xbox Console
Reading reading open tray
Make sure the disk is facing the correct direction and close the tray.
Dec 29, 2009 | Microsoft Xbox 360 Console
Disc tray wont work right
Hi
You can check the tip i have created on solving this issue of open tray, let me know of this help and do take time to rate my solution
Happy Gaming
http://www.fixya.com/support/r3803844-troubleshooting_steps_xbox_360_open
Regards
KreativeGeek
http://gamingbox.wordpress.com
Dec 20, 2009 | Microsoft Xbox 360 Console
Insert game and it just says open tray
either the disc is ultimately scratched or your drive is malfunctioning.
To fix mine i just bang the xbox on the top and turn it off and back on.
Sep 27, 2009 | Microsoft Xbox 360 Console
Drive tray keeps opening and does not read disk
Do you mean it will not stay closed?
if that's the case the (closed leaf switch) in the
drive is shorted together . gotta open it up
to fix it . that normally happens when someone
trys to open it up with a thin screwdriver.
If the laser was good (reading games) before the tray problem
its still good.
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Dvd rom will not work
The cover is warped. There needs to be just the right tension on the arm that lifts the eye of the drive to read disks properly try pushing down on the cover when you have it apart. So that you bend it alittle.
Aug 03, 2009 | Microsoft Xbox 360 Console
I put disc in the disc tray and says its reading then it just says: open tray?
wel then theres a problem wit either the game or the reader under the disc tray
Apr 14, 2009 | Microsoft Premium System for Xbox 360
When i put the game in it says reading then just says open tray and wont read. it used to read after a few try but now it wont work no matter how many trys
Most likely it is your laser lense is dirty. Crack the case get in to the DVD drive open it. While in there give it a general cleaning then clean the laser lense with glass cleaner and a q-tip. Three other things to check. There are three motors in there one slides the tray in and out when you hit the eject button (small hole lower left of metal box under drive) another moves the laser when the tray moves back in you should see the laser move slightly and the lense bob up and down and light up, third is the spinner motor put and disc in the tray and close the tray the disc should spin up if it doesn't then the motor is bad. If all these things have work ok put it back together and test it out.
Mar 23, 2009 | Microsoft Xbox 360 Console
It always reads it as a movie or it will say open tray
your laser is fried almost that's why you have that problem.
I replaced the laser my console had the same problem.
Jan 20, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
