Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The machine won't empty or spin - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I have same problem i need help to
Posted on Dec 11, 2009
SOURCE:
Won't spin with clothes in. Will spin when empty
Check the drive belt and tension arm spring and make sure it has not dislocated itself. The drive belt is the most likely problem if the motor is running during the spin cycle.
!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 12, 2012 | Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Kenmore Washing Machines
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
My machine will not spin dry and empty the water after a wash, the lights will just blink and the machine will stop.
My machine won't spin or drain and just goes on and on for hours not taking notice of the cycle I put it on, can anyone help?
Jan 03, 2011 | Whirlpool AWG5122 Front Load Washer
My bosch wfe2021gb won;t spin. how do i diagnose
Try a spin when empty if it spins ok the brushes are wearing on the motor
Jun 26, 2010 | Washing Machines
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
93 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
