Question about iLO LCT32HA36 Television
I have an ilo 32 in wide screen lcd tv LCT32HA36. The tv was on then it went off. there has not been any power outages,I unplugged it,when I plugged it back in, the red stand by light came on when i tried to turn it back on, green light briefly comes on, then goes away, and the tv does not turn on. the red stand by light is not even on, tried same proceedure again, unplugging and plugging, and then manually turned on the tv same thing happened. what do you think the problem is? I even plugged it in to a different outlet.
    President:
  • iLO Master
  • 1,779 Answers
Most likely defective capacitors in the power supply.
Posted on Dec 11, 2009
    President:
  • iLO Master
  • 777 Answers
Lct32ha36 uses power board MLT169B, which is well known to cause this problem due to cheap capacitors.
There are quite a few blogs around the web that document it and here's just yet another one with a bit more details:
http://blog.coppelltvrepair.com/2011/06/akai-lct3201ad-lct3285ta-does-not-power.html
If you have more questions do not hesitate to ask.
I must point out that replacing the caps is almost as easy job as you can get that involves soldering iron.
In addition, I would recommend against spending $60 on a used board unless it has already been serviced for that problem.
Mostly because you may end up facing it again fairly soon.
But mainly because it's just too easy and cheap to fix it by yourself or even have others fix it (properly!) for you.
Posted on Jun 24, 2011
My tv shut off and now no power at all its a Ilo 32HD
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Jul 30, 2014 | Generic 32 ilo lct32ha36 1080i hdtv...
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
I have a lct42ha36 ilo tv. the screen went black still had sound but then heard 3 pops then power shut off and will not turn on
Check its power regulator board for faulty component. It will be best to replace it as card basis.
Apr 20, 2012 | iLO LCT32HA36 Television
Analog or digital
Hi, Lucky you, your ILO Tv has an ATSC tuner which is digital. This should Fixya!
Mar 05, 2009 | iLO Televison & Video
No Power
It's possible your TV when into protection mode. This happens when a part is burned out inside your TV to prevent further damage.
Try unplugging your TV for 30mins. Then see if the problem still occurs.
If the problem is still there, you may have to take it to a repair shop to diagnose the problem.
Feb 09, 2009 | iLO LCT32HA36 Television
TV wont' turn on
The failure on your LCD is due to a defective power supply. Leaky or dry capacitors is the reason for the failure. Replacing or repairing the power supply should fix your LCD.
Contact this website and ask them if they have any power supplies in stock.
Good Luck.
Sep 04, 2008 | iLO LCT32HA36 Television
Ilo LCT32HA36 LCD TV
HI, I AM JESSICA PORRAS. I PURCHASED AN ILO PLASMA 42" T.V. FROM WALMART IN 2006. THE T.V. LASTED 1 YEAR AND POPPED A FUSE. THE SCREEN WENT BLACK, BUT VOICE IS STILL COMING THROUGH. I DID HAVE WARRANTY AND MY MONEY WAS RETURNED. I HAVE A QUESTION AS FAR AS THE BRAND 'ILO' GOES. CAN THE PARTS BE CROSSED WITH ANOTHER BRAND? SINCE THE FUSE HAS POPPED, WE HAVE REPLACED THE FUSE 3 TIMES, AND IT KEEPS POPPING THE FUSE. THE LAST 2 FUSES HAS BEEN A CERAMIC FUSE AND IT WILL BURN THEM. THERE IS A SHORT AND WE ARE WANTING TO CHANGE OUT THE TRANSFORMERS. IF I CAN HAVE A TECHNICIAN CALL ME @ 432-553-6784cell OR 800-880-2817work M-F 8-5PM CST. YOU CAN ALSO RESPOND BY E-MAIL. THANK YOU, JESSICA PORRAS
Feb 04, 2008 | iLO 3200 32 in. LCD Television
32" lcd ilo tv
Call 800-726-4405 - but you will have to ship the television to California at your expense to have it repaired or replaced.
Nov 16, 2007 | iLO LCT32HA36 Television
iLO LCT32HA36 Television Logo
711 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
