Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Ignition issues I have a tohatsu 9.9 h.p. It starts OK and revs ok in neutral, but when I put it into gear and try and rev/accelerate, it kind of dies out, starts chugging and runs like only running on one cyclinder. Any thoughts
  • 4 Answers
Could be a hole in fuel pump diaphram
Posted on Dec 16, 2009
I have a 1986 yamaha virago 1100..when I first start the bike and put it into gear it dies out...when I rev it to 7000 rpm it goes into gear and is fine for the day until the next day
Hi, Floyd and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Re dies when put in gear Road Star Forum Yamaha Road Star
Engine dies when put into Gear
Stalls when put in first gear
Yamaha 1986 XV1000 Service Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 04, 2016 | Yamaha Motorcycles
Why does my 1992 4runner die when I put it in gear?
that could be an air/fuel problem ,does the engine rev ok when not in gear ? if it does then probably not air/fuel. the autobox speed sensor might be the fault have it checked at a auto trans repair shop
May 11, 2014 | 1992 Toyota 4Runner
Mercury elpto 90
i HAD THIS ISSUE SERVERAL YEARS AGO , TURNED OUT THAT THE PROP WAS SIZED WRONG,
Jun 27, 2013 | Boating
1991 Suzuki Swift GTi very low idle and stalling
Oxigen sensor. Check accelerator pot also, and fuel pump.
Jan 13, 2013 | 1991 Suzuki Swift
Looses power under a load put in neutral give gas runs good
sound like fuel filter stopped up.if you have distributor type engine your idle speed could be too low and ignition timing off a little.
Dec 11, 2011 | 1995 Toyota Camry
2007 Mazda CX-9 has recently developed a front end vibration under heavy acceleration. Vibration disappears if shift to neutral at highway speed, engine rev's smoothly in neutral. Suspect engine...
Try to rev the engine while at neutral if you get the same vibration to pinpoint if its from the engine or the drive shafts. If the issue occurs at a certain rev it may likely be the variable valve unit. Check if possible if you can get errors from the computer.
Sep 08, 2011 | 2007 Mazda CX-9
I have a 1999 Pontiac firebird. The car started to die on me. It starts but when I push on the gas it dies. Sometimes u can start it and rev it up but then when u put it in gear and push on the gas it...
a defective tps sensor could cause this kind of defect..tps is the throttle position sensor..located at the intake manifold connected in the accelerator cable
Jul 20, 2011 | 1999 Pontiac Firebird
1998 Kawasaki ZXR 250 will not rev past 2000 RPM
Hi, Cheynedharri and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Faulty or corroded kill switch.
11. Accelerator pump damaged or not working.
12. Water or dirt in the fuel system, carburetor or filter.
13. Restricted, blocked or kinked fuel line.
14. Fuel tank empty.
15. The gas cap is not venting properly or fuel tank venting system blocked, loosen gas cap and go for a test ride.
16. A failed fuel pump, pressure regulator and or fuel injectors.
17. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
18. Needle and seat stuck closed in the float bowl.
19. Petcock clogged or damaged.
20. Lean angle switch is faulty or needs adjustment.
21. Catastrophic engine failure, perform a compression test.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
My ZXR 250 1991 wont rev past 2k revs
https://kzrider.com/forum/3-carburetor/534205-help-my-bike-won-t-rev-past-2000rpm
Kawasaki Ninja 250R Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
May 06, 2010 | 1998 kawasaki ZXR 250
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
343 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
