Question about Music
My CTK-2000 Casio won't turn on. It's plugged in, and I've turned it on.
  • jtrwhitechap Dec 11, 2009
    It does, but the piano is only two months old.
    Problem Solver:
  • 11 Answers
Does it have a rubber power on button? If ss, it's probably worn oujt. Replace it.
Posted on Dec 11, 2009
  • specs2 Dec 11, 2009
    Than return it to the shop for a warranty repair?
What do I need to do with my Casio CTK 700 which will make it run on batteries?
If you turn it over, you will see the battery compartment. It runs on 6 AA batteries. Here's a link to the manual. Instructions are on page 13.
http://support.casio.com/pdf/008/ctk_496_700_e.pdf
Feb 25, 2015 | Casio Music
Ctk-651 sustain pedal working backwards
Buy sustain pedal made for CASIO or switable model.
Pedal for Yamaha or Roland will work in reverse on a Casio.
If you cannot return for exchange, then open up and solder a different type of micro switch.
Dec 31, 2013 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
Manual Casio CTK-650
Hi! When I turn on my keyboard it shows "03.2" on the multifunction display and the lights of "Split", "Digital effect" and "Touch response" remain "ON" and in someway it get blocked for the most of the functions. I cannot turn off that lights. Please, help me!!! You can answer me to dramosm@hotmail.com Thank you very much
Sep 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
I have a Casio CTK 551 Keyboard, when the AC adaptor is connected and power is turned on, the Keyboard lights up for a few seconds then turns off. I noticed no red light lights up when the AC adaptor is...
The adapter has a problem... likely a poor connection of input power that briefly contacts building up some voltage that is then stored in the capacitors in the adapter which then discharge quicklly when you turn on the Casio. The adapters with FIXED blades OFTEN have problems contacting the connections in wall receptacles and extension cords. You may need to bend the blades slightly or use a better receptacle like connector. IF your adapter has a three wire cord from it to the wall receptacle, those SOMETIMES don't seat well...
Apr 10, 2011 | Casio Ad5mr Power Adapter Lk Ctk Wk New...
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 | Casio Music
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 | Casio Music
My ctk 2000 casio keeps shutting off
Replace the batteries and get an AC adapter for it! These do NOT work when voltage os too low.
Nov 21, 2009 | Music
Casio CTK-671 No Sound
Try plugging in a set of head phones , if you get sound that way the input jack may be causeing the prob. try pulling it back an forth a few times, sometimes this will free up the head phone jack. I hope its that simple . May be some one will have another idea Good luck DFD please rate me TK U
Apr 09, 2009 | Casio Music
Casio CTK 2000- won't work with adapter
If you have a volt/ohm meter try checking to plug that goes into the keyboard for voltage on the DC setting. If there is none, you will have to replace the adapter. Be sure to plug the adapter into the wall when you check it or you will get no reading. If that is not the problem, then it is probably the receptacle for the DC end of the power supply. What happens is that if they get bumped the solder connector on the circuit board breaks. If you do not feel comfortable fixing this yourself, you will have to find someone who is capable. Hope this helps.
Apr 08, 2009 | Music
How to do a master reset a casio ctk 496
According to the manual for the 496, "All keyboard settings are returned to their initial defaults whenever keyboard power is turned back on after being turned off by operation of the Power/Mode switch or Auto Power Off.
Nov 26, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
281 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
