Question about HP Photosmart C4180 All-In-One InkJet Printer
I am having trouble replacing the ink cartridge. is there direction on this anywhere
    Problem Solver:
  • 16 Answers
HP Photosmart C4180 User Guide
Once you click the above link, simply choose your current OS and then download the user guide.
Posted on Dec 11, 2009
SOURCE:
Having trouble removing ink cartridge on hp e709n printer
Hello Sandi,
According to the product information you provided in your post, the following information should be able to provide you with the information needed to help you remove and replace the ink cartridges for your printer.
Ink Cartridge Removal Steps:
Keep your printer plugged in and on during this process.
1. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage stops moving before proceeding.
Illustration of cartridge access door
2. Each ink cartridge will have plastic tabs located directly in front of them. Press in the tab on the front of one of the cartridges, and then pull it out and up to remove it from its slot. Once you have pressed the tab, you then pull up and out on the cartridge and it should come out easily.
Illustration of process:
3. Repeat this step to remove all cartridges from their slots. Remember that each ink cartridge will have to be removed individually if your printer has more than one cartridge.
Replacing the cartridge with the new one:
1. Remove the ink cartridge from the packaging and then remove the protective covering.
2. Hold the ink cartridge in the same position as you removed the old ones. Push in and then down on the new ink cartridge which should lock them into position with the tabs automatically and you will you will usually hear a clicking noise when this is done.
3. Close the cartridge access door. The printer will automatically reposition the cartridge print head assembly for you.
This should complete the process and you should now be able to print. Some printer will ask or recommend that you print a test page so that it can calibrate the desired ink usage, position, darkness, etc. If this appears on your screen just follow the directions as prompted to complete the test page.
I hope this provides you with a bit more clarity for removing and reinstalling your printer ink cartridges. If you have any further questions or need additional assistance, please feel free to ask. Have a good day.
Jun 20, 2012 | Unknown Office Equipment & Supplies
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
Don't know exactly where to drill a hole to refill Epsom T0711 printer ink cartridge. Can you help?
Thanks for using Fixya.
You won't need to drill hole anywhere.
Visit this link to get all the instructions required to refill the ink in Epson T0711 cartridge.
But remember you would need a chip resetter gun to re set the chips on the ink cartridges after you refill the cartridges.
Visit this link to buy Universal chip reseter if you don' t have.
Good luck and have a nice day.
Jul 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How to load ink cartridge into cx3900 printer
Here is a link to a good website to provide you a downloadable pdf file which is a graphical chart detailing how to Load paper and replace the ink cartridges for the Epson Stylus CX3900 series.
Epson Stylus CX 3900 All-In-One Inkjet Basic Start up Chart
(Includes instructions for replacing Ink Cartridges)
Hope this helps!
-Mactechtrainer
Jan 26, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Trouble refilling lexmark 2650 ink cartridges
hey dude have you find any solution for your problem?? i've got the same problem here :( can't do anything
Aug 16, 2009 | Lexmark X2500 All-In-One Printer
I am trying to find ink cartridges for my compaq u600.
Lexmark made that printer for Compaq. The numbers on the cartridges are a Lexmark number, if you go to a store that sells ink cartridges for Lexmark, ask for a number 50 or 60. Or go to google and search for Compaq A1500 ink and you will get lots of choices to buy from, usually with Lexmark model numbers.
Jun 09, 2009 | Compaq A1500 All-In-One InkJet Printer
New Canon ink tank not recognized.
Check that the cartridge chip is not soiled or damaged in any way... Give it a quick clean, check that there's no ink anywhere else on the cartridge as there are sensor points that an LED uses to check the cartridge ink levels too.
If none of that works, phone Canon and request a replacement as some cartridges are known to have faulty chips.
Jan 29, 2009 | Canon MX700 Office All-In-One InkJet...
Printer goes throught the motions of printing, but what comes out is a clean page - no ink
Some of them do. Try going into the printer properties and disabling bi-directional support. This will not allow the printer to check. HP has set some printers to not function if its disabled, but hopefully yours is not one of them.
May 07, 2008 | Office Equipment & Supplies
HP Photosmart C4180 All-In-One InkJet Printer Logo
52 people viewed this question
Clive
Clive
Thomas F. Schneider
