Question about Ximeta NDU10-120 (890345000151) 120 GB Hard Drive
Will not open. clicks a few times and freezes up the pc
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 6 Answers
There is a very good possibility that this hard drive has crashed. However, there is a little trick you can try. Disclaimer: There is no guarantee this will work and there is a very good chance you will not be able to retrieve your data. If data is very important, I would recommend taking it to a data recovery specialist. If you would like to try on your own, seal the hard drive in a ziplock freezer bag and freeze overnight. Try to access your data as soon as you remove the hard drive from the freezer in the morning. (I have seen this trick give up to an hour or two of use out of a dead drive.)
Hope this helps
Posted on Dec 11, 2009
My recorded tv freezes when trying to watch them
The whole thing freezes? As in the mouse or keyboard won't even work?
If it's just the video that freezes and you can shut it off, most likely it's a codec issue. Which is dumb since everything you're using came packaged together in the unit. Installing a third party codec pack would solve this issue.
Though, if you're whole PC is freezing when you try to play a video then I have a few other questions to ask you to narrow the potential problems down:
1. Open up the player that opens automatically when you try to watch something, but don't load a video into it. Did everything still freeze?
2. If not, then open a video file that is not something you recorded from TV, like a DVD or a video clip from the net. Did it freeze then?
3. When it freezes, does it freeze instantly? Or does it run for a little bit then freeze. If the latter is the case, what happens in the time between opening the file and the lock down?
Mar 06, 2014 | Acer Aspire All-in-One Desktop PC - Silver...
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
How do I stop Skype freezing oon my laptop ?
Try This:
CTRL+ALT+Del this will open Windows Task Manager Under Application tab right click on Skype and left click on "Go To Process"
Left click on End Process. this will stop Skype without rebooting the PC.
After opening Skype does ALL programs Freeze? If so then its probly Malware running on the PC.
Reboot the PC into safe mode and run a full scan with your antivirus program.
Good Luck!
Aug 19, 2012 | Acer Aspire One PC Notebook
My home page freezes after a few minutes of inactivity. If I have another internet site open, it will also freeze. Then when I click on my home page it is totally white. I then refresh my home page and go...
I would run a good virus or malware program, there are some very good and free ones available. Try Malwarebytes, AVG and Spybot S&D, all available free and all very good. Hope this helps.
Jan 21, 2012 | Toshiba Satellite A505-S6975 Notebook
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
Hp computer freezes for a few seconds at a time after repowering then is fine then freezes. Only solution so far is restoring to an earlier date. Does anyone have a solution for these intermitent freezes?
go into msconfig or the system configuration utility and then click on the startup tab. This will show you all the programs that are running while windows is loaded. Uncheck the programs that you don't want running and then click on Apply and then click on OK and then let the computer restart. Your computer should run a bit quicker and the freeze ups should pretty much go away.
May 05, 2009 | HP Computers & Internet
My Local Area Network icon Indicates that iam connected but i can't get internet.Sends few packets the received ones freezes. Andrew From Kenya
Log in as a Adminstrator
open the command prompt or click on run and type cmd , then enter.
Type the following commands
ipconfig / release
ipconfig /flushdns
netsh winsock reset
after you done , restart the computer .
It should work now
Apr 14, 2009 | Computers & Internet
Weird clicking noise and computer freezes.
Laptops have very few moving parts. Your problem is more than likely either a fan or your hard drive. Remove the hard drive, start the computer up and just let it run for awhile. If the clicking noise never comes up then thats your problem. If it does, its probably a fan.
Disregard anything on the screen itself, just let the PC run. It sounds like after the hard drive has been spinning for a minute a motor starts to die.
Jan 29, 2009 | Acer Aspire 5100-3357 Notebook
WINDOW FREEZES WHEN OPENED MESSAGE SAYS ALPS POINTER PROBLEM
my compaq laptop freezes up when not used for a few minutes and then data is lost and I have to reboot it!
Jan 04, 2009 | HP Pavilion dv5170us Notebook
Need Help-Nextel i850 keeps freezing up between opening and closing
go to motorola.com/iden
click united states
click support
click software downloads
(if you have pictures and videos download iden media downloader to retain them)
click software upgrade
click your phone model
make sure you select a date within a year for the warranty info
you will need a data cable to make this work
try to redownload the software to your phone
this might help
Thank You
Sheeraz Khan
Masalama
May 25, 2007 | Nextel i850
Ximeta NDU10-120 (890345000151) 120 GB Hard Drive Logo
74 people viewed this question
Top Ximeta Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Ximeta Computer and Internet Expert? Answer questions, earn points and help others
