Question about Cyberhome CH-DVD 300 DVD Player
Need device code
I need a device code so i can enter it in a universal remote, i lost the controller
I have a cyberhome dvd ch 300 and the screen has blanked out but the voice is coming through clearly. It is not showing from the usual video output but it shows very wavy on the other progressive scan lines what can i do
Posted on Jan 25, 2008
I have lost my sdtv magnavox tuner box remote and I have a sony universal remote control how do you program the box to the remote control?
Find the owner's manual for the universal remote (you may have to get the pdf version online) and look up the model number for the tuner in the list of supported devices. The manual will have instructions for entering the code for that model number into the remote.
Jun 25, 2015 | Sony Televison & Video
I have my philips universal remote but i lost my codes, how do i access codes online
Hello
Enter the site given below. Codes can be searched under the brand name. There is not a code list can be seen in net for this device. You can get the code for your device from here.
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SRU3004/27
Click on "remote control code finder' under "Product support" and enter the enter the device type in "choose device type" column, and follow the instructions. OK.
May 31, 2011 | Philips SRU3004 Remote Control
Lost programing instructions and codes
1. turn on device
2. press setup (underneath on/off) till red light stays on the take finger off the button
3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once
4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press
5. press and release enter to install code
3-Digits Universal Remote Codes
4-Digits Universal Remote Codes
GE #24912 Universal Remote Instructions
GE Universal Remote Instructions
Apr 15, 2011 | GE JASRM24912 Remote Control
I have lost the ge universal remote guide for the codes its a ge sku 24914 universal remote i need the codes to program the remote
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
Jun 13, 2010 | Universal Remote Control GE174Universal...
Lost codes for v.old universal remote
All universal remotes work about the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | Sony SLV-SE720 VCR
Device code for universal remotec remote
I need the model number of the remote to help you.
Thanks,
Jim
Apr 15, 2009 | Universal Remote Control 6-Device...
Program the RCA#rcr312 universal remote control
hold the code search buttton until light comes on then select the device you are programing and enter code
Oct 22, 2008 | RCA Universal Remote Control
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
General electric Universal remote control codes
try out this.mash and hold the set up button.when the indacator light bilnks ,press the item in which you want coded.turn that item on by hand,point to it with remote and mash the power button up to 300 times until the item turns off.then hit enter.do not go to to fast,if you over shoot the code you will have to start all over again.let me know if this works for you. halfbreed76. e-mail mckenithfamily @net zero.com
Nov 21, 2007 | Directed 434MHZ Remote Control
Lost code and instruction book?
Orion Codes: 035, 121, 135, 191, 394 Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.pdf Hope this helps, Good Luck :) Please Vote
Jul 10, 2007 | GE RM24911 Remote Control
Cyberhome CH-DVD 300 DVD Player Logo
74 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
