Thats usually caused by failed capacitors on the DM board. You can get the V26 DM repair kit from www.tvrepairworld.com which should correct that issue. The kit contains the parts and the CD with instructions.
MANUAL PROGRAM CODE SEARCH YOUR XR11 REMOTE TO YOUR TV: 1 – Turn ON the TV you will be using with the XR11 remote. 2 – PRESS AND HOLD the SETUP button (bottom left) on your XR11 remote until the LED status light (top of remote) flashes from Green to Red. 3 – Begin manual TV code search by entering 991 on the XR11 remote. 4 – The LED status light will flash Green 2 times. 5 – Repeatedly press the CHANNEL UP button on the XR11 remote to search through the TV codes. 6 – Keep pressing CHANNEL UP button on the XR11 remote until the TV you are programming turns OFF. 7 – After your TV turns OFF press SETUP. 8 – The LED status light on your remote should flash Green 2 times. 9 – Press the TV Power button on the XR11 remote and if the TV turns ON, your XR11 remote is programmed. Be sure to hold the SETUP button until it flashes Green 2 times after your TV turns OFF.
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
SYSTEM RESET If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may turn on the TV again. Changes you made the last time the TV was On before you used the SYSTEM RESET button may be lost, however, the changes you made previously are not lost. POWER/TIMER Indicator The green light is a multi-function indicator. This light will flash rapidly for about one minute each time the TV is plugged into the wall electrical outlet, when power is restored after a power failure, or using the SYSTEM RESET button. Do not attempt to turn on the TV again during this period. Wait for the flashing to stop and the light to turn off, before attempting to turn the TV on. While the TV is powered on, the light illuminates steadily. If the TV has been programmed to turn on automatically using the Timer feature,
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
