Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
D-link wbr-1310 Unable to access the router with 192.168.0.1 even though it is working OK. I want to change channel and make it secure To do it I have to reset every time ! How can this be prevented ? Thank you
  • 2 more comments
  • Laval Desbiens Jan 20, 2008
    the only remaining solution is to reset but I have been re-setting for
    some time now and I hope to find a permanent solution - thank you both
    re-setting seems to be the only solution for now, albeit not a permanent one - thanks - Laval
  • Laval Desbiens Jan 21, 2008
    Seems my problem was fixed by getting an update for the WBR1310 from the D-Link site.
    One D-link rep told me to use only WEP and go to channel 11 !
    I am now using channel 9 and WPA 2 and it works fine.
    Guess one had to up-date before doing anything else IF one can get online
  • KingKhan Jan 28, 2008
    my xbox is connected to this router and when i go to type 192.168.0.1
    is says page cannot be found and its pissing me off because i cant get into any of my friends games
    Scholar:
  • 112 Answers
First check to be sure the ip address of the router IS 192.168.0.1, do this by clicking Start/Run and in the Run window type CMD and hit the enter key, this will give you the MS/DOS command window, at the courser type ipconfig /all, then check the ip address shown for the gateway which is your router. If the ip is correct, put a cat 5 cable from the router to the computer and type http://192.168.0.1 if that is the correct ip address and if it does not give you the logon page for the router reset to router to factory defaults as per owners manual. if this works please rate the solution as a FixYa. Thanks BPCS
Posted on Jan 20, 2008
When I attempt to secure the dlink network at 192.168.0.1,
my network name does not show up on available networks.
Router is a DLink 1310. Dlink says my router is fried, my isp
later said it wasn't. It has been reset many times. The tech
rep has tried the WPA-personal security setting and WPA 2 as well as WEP. They will give me a new router.
ISP says to try WEP.
Does Vista play a role in configuring the wireless router. All tech rep's have been awarem of that but I'm still not online with a secure wireless connection.
Thanks! JWH
Posted on Jan 21, 2008
  • 4 Answers
Hi Laval,
The router could use any of the following as the default address.
192.168.0.1
192.168.1.1
192.168.2.1
Are you able to get to the logon page when you type in any of the following?
About two months ago, we started noticing our wireless connection cutting in and out. It has gotten worse and now, we can't even get on the internet. It's not our computer because my daughter's computer...
Reset the router to factory settings and test. Please remember that security settings may be restored too here, so you may need to encrypt the signal. You will need to log into the router's configuration page in order to achieve these. Also try changing the channel in terms of broadcasting... and test again. I hope I have helped here. Good luck.
Oct 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My WBR-1310 doesn't do wireless to my laptop.
theres a couple of version of this router http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3 I'm using the manual from here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
on a working PC download and install this program http://www.xirrus.com/library/wifitools.php this will detect all the wireless signals being broadcast - see if the router is actually broadcasting - if it is detected on your PC then it may be that 1) the firewall is blocking access or 2) the security code is entered wrong - -log into the router and remove the wireless security and see if you can now detect
Mar 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How to secure connection on WBR-1310 d link
To secure the wireless network, you will need to access the router set up.
Is there any computer connected to the router ?
If not then you will need to connect the router to the computer .
Then check the IP address of the computer and open the router set up.
Click Here for step by step solution on how to secure the network
Nov 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My router (d-link WBR-1310) keeps dropping internet every 10-15
Try to access the configuration page of your router and look for channel number. Change the channel number to 11 or 13 whichever is available. It should work fine after that. If it still does not work, you can hard reset it by pressing the reset switch on the router. However, then, you will have to configure all the settings again.
Nov 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-link 802.11g wireless router security key
First, go to your router's ip address (192.168.0.1).
Then, login to your router (default username: admin default pass: blank or admin)
There, under tools or network security or similar to that sort, look for your network/WEP key. There, you should be able to find your network key to access the router's network, and even change it if needed.'
Hope this helps, please rate ^_^
Jun 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wii wifi connection
Try to uncheck UPnP Enable on your router located on advaced network setting. or try reconfiguring your wireless network settings.
Dec 27, 2008 | D-Link 802.11g Wireless Router WBR-1310...
I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
Nov 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Unable to connect to the internet
Mike, Try setting up a new connection in Internet Options in Control Panel. Please let me know how this works for you.
thanks
Jan 24, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Cannot access the WBR-1310 webpage
if you are wireless, after a reset you need to connect with the router using an RJ45 lan connector lead. Reboot your notebook, while connect to router and then type in the default address for the set up page normally 192.168.0.1
Oct 05, 2007 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
1,591 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
