Question about Linksys WRT160N Wireless Router
No internet connection
I have Linksys wireless "N" router connected to a AT&T DSL/broadband modem/router. When I attempt to access internet on my desktop (wired connection), I am unable to access the internet. Same for wireless connection to my laptop. I believe everything is connected properly, and I followed the instructions on the set-up disk. Thanks
    Novelist:
  • 94 Answers
When connecting the devices make sure that you turn on the device in this manner: modem (wait for the lights to be solid) then router, then the computer.
Check if you can get online, if not then follow the steps below:
1. Open a web browser and type this in the address bar: 192.168.1.1
2. Then you will be in the setup page of the router. You need to know what is your connection type obtained from your ISP.
If DHCP, internet connection type should be: Automatic Configuration - DHCP should be selected.
If PPPoE, select PPPoE and type the username and password provided by your ISP.
3. Then save the changes.
Once that the internet connection is working from the PC hardwired connected to the router, then check the wireless settings under the wireless tab. Take note of the SSID, wide channel, and the wireless security and preshared key.
Put those settings on the wireless adapter of the laptop and you should be able to get online.
I hope this works! Good luck!
Posted on Dec 15, 2009
SOURCE:
How do i connect my cable to router and to cumputer
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 17, 2012 | Linksys Wireless-G Broadband Router
Not able to connect with internet using my router
Had this work before?
If yes, and you're using Cable modem then just Power cycle the Linksys router by unplugging / plugging the power cord.
If not, then you have to configure it with the correct settings for Cable and DSL ISP connection.
Check you physical connections; Modem (cable or dsl) - to Linksys (WAN or Internet port) - then plug (wired) your PC to check internet connection.
Good Luck!
Angel
Jul 09, 2010 | Linksys Wireless-G Broadband Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Will not connect to internet whether it is wired or not
connect the broadband modem to the internet port of your router (probably is blue). Then connect your pc to the router.
You have to set your router to act as dns.
Jan 20, 2010 | Linksys Wireless-G Broadband Router
SETTING WIRELESS
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
Oct 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
I have a DSL router provided by frontier. I am trying to make my desktop wireless. I believe that my DSL router functions as a modem also. I purchased a Linksys wireless broadband router. I can't not...
Your router should just be that, a router. Your connection is probably like fibernet the modem is actually on the outside of the house. This may help or may not but I have a linksys wired router that works very well but you have to go to their website in order to set up the router. You may need to look through your papers and find the web address to connect to the right site.
Apr 17, 2008 | Computers & Internet
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Linksys WRT160N Wireless Router  Logo
399 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
