Question about Akai LCT3201TD 32 in. LCD Television
The TV won't come on. This began a while ago, but the TV would eventually come on. Now it doesn't do anything. The TV is 3 years old. Any idea how much a repair would run?
  • Akai Master
  • 8,457 Answers
It cost about $300 dollars parts,and labors.About half the new one.
Posted on Dec 11, 2009
    Brigadier General:
  • 3,917 Answers
Hi
please inspet the circuit board of your Tv...and chek whether any wire is broken which needs to get soldering .Resoldering the circuit will mend your problem or please check whether any fuse is needed to be repalced or not.
Thanks for contacting fixya.com
My 18 year old top freezer Inglis refridgerator has started to clunk. This noise began a couple of months ago. The clunk is fairly loud ( heard over the TV) and happens once every couple of hours. The...
The clunking is because the compressor has a broken mount and it clunks when it shuts off... this will eventually cause bigger problems, but probably you will need to replace the compressor to fix it...even so just check that a bolt did not come loose and that it may be a simple fix...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
1995 Saturn SL2 Continues To Stall
I had same problem a couple years ago with 95 sl2, i had new wires and plugs instaled and they replaced the valves also. car works great since then...
Jan 07, 2009 | Saturn SL2 Cars & Trucks
No red in picture
It could be a dry solder joint on the base socket pcb. Try resoldering the base socket, and try for dry joints on the main board also. Check if the rgb voltages are steady on the crt driver transistor bases.
Jan 10, 2008 | Televison & Video
HITACHI ULTRAVISION PROBLEM
Hi, That`s an easy one, you have a bunch of broken solder joints on the sweep board, if you are proficient at soldering you can fix this yourself, if you are NOT then call a tech out, this is a cheap, quick repair, get it done and start enjoying your set again, hope this helps, Happy Holidays.
Nov 30, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
No audio
9 times out of 10 a TV like that which has no audio is fine and the audio settings are not right or it is a cable box / satellite receiver problem. If you are using cable then connect the cable directly to the TV, tune in an active channel and set the volume about half way. If you do not hear any sound then, using the remote, go into the menu, scroll to the audio page and make sure the speakers are not set to OFF and also make sure the audio is not set to SAP. If you have checked all that and everything is set correctly and you still have no audio, then your audio output IC is probably bad or cracked and should be resoldered or replaced by a qualified tech.
Jul 30, 2007 | Sony KP-53V75 53" Rear Projection...
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Akai LCT3201TD 32 in. LCD Television Logo
103 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
