Status says protect on JVC ca-hxc6
We have stripped the speaker wires and inserted them back in and it continues to say Protected. Is there anything else that we can do?
  • 1 more comment
  • Anonymous Mar 16, 2008
    ON LAKE
  • 92matt Sep 01, 2008
    Im havin the same prob.
  • Anonymous Dec 28, 2008
    MY SISSTEMJUST DISPLAY PROTECT ON SCREEN AN AND I CAN MAKE ANY FUNCTION WORK
System keeps reading protect
Posted on Jun 24, 2010
STAR NOT GOOD ON END OFF
Posted on Mar 16, 2008
My jvc stereo is stuck on protected and it won't change the radio station off protected
Radios that are in "protected" mode often indicate a short in a speaker wire or a really bad speaker. Disconnect all eight speaker wires: white, white/black, gray, gray/black, green, green-black, violet, and violet/black. Turn on the radio and see if it still shows "protected". If it does, the radio is defective. If not, connect each pair of speakers back one at a time and see if it goes into protected mode. The one that causes it is the bad wire/speaker.
Dec 22, 2013 | Car Audio & Video
When i turn on my stereo, the protect mode comes on then shuts down and turns off, i checked the wiring to the speakers and the unit is not near anything for it to overheat, what else can i do or what else...
Turn it on naked...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 30, 2011 | JVC HXC6 500-Watt Stereo System with 5-CD...
My JVC CA-MXKA3 it say protected when i switch it on, i have also try to switch it on weout speakers but it still say the same thing. Please help me on what to do
http://www.retrevo.com/search?q=JVC+MX-KA3
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 18, 2011 | JVC MX-KA3 CD Shelf System
My JVC stereo receiver CA-HXC6, how do i get itout of protect mode? it turns on then goes right to protected and turns off
google stk428-610 ic an stk428-640 ic an replace them , they have to be solder in , don't try this if u don't have experience
Sep 09, 2010 | JVC HX-C6 Shelf System
I have a jvc home stereo model number CA-HXC6 i have had it for a few years its on protect mode and i cant get it off dont know how it cuts off
Turn off power, unplugg unit, very carefully check speaker wire connections making sure no wires are touching each other or the back of the unit same at speakers connections. Also check speakers. Blown drivers can short terminals internally. This is the most likely problem. Remove the short, unit will come back on
Dec 21, 2008 | Bose 901 VI Main / Stereo Speaker
Protecked mode?!
when i had this problem my wires were touching the case. other times the wires were touching eachother
Mar 23, 2008 | JVC MX-KB30 CD Shelf System
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
Protect
hi, ya absolutly... please check the speaker wires, some wire is shorted, remove all the speaker wires from the system and then power it on to confirm it.let me know
Jan 03, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Protect
Protect mode would indicate that the system is shutting down due to a fault in the output which drives the speakers. You can check the speaker wiring, are there an loose or frayed wires? Any small "whiskers" or wire touching anything? Check the wire all the way to the speaker for damage, some pets love to chew wires! Are you using the original speakers or added extra? The impedance of the speakers must be in the range shown on the back of the unit. Have you perhaps had the volume up very high? This could result in speaker damage that could also cause this error. Try disconnecting the speakers & see if the unit powers up, if it does then put the speakers back one at a time to discover the faulty one. If all this checks out OK then the output stage itself is probably faulty & that's a job for the repair shop. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 17, 2007 | JVC HXC6 500-Watt Stereo System with 5-CD...
533 people viewed this question
 Grubhead
Grubhead
