Question about Gateway M-6843 Notebook
I've had my Gateway M-6843 Notebook for about 18 months. Since the day I bought it from Best Buy, the AC adapter port has been finicky. I'll be using the laptop with the adapter plugged in and the battery charging. Then, if I make the slightest movement, or the adapter cable shifts even a bit, the external power source will disconnect, and the notebook will start running off of battery power only. Until now, the problem could usually be resolved by fiddling with the adapter in the port, until the external (AC) power source reconnected. However, in the past day or so, nothing works. Even when the AC adapter is plugged in, the notebook continues to run off battery power only, which is, obviously draining the battery. And there's no way to get the battery to recharge, no matter how I position the AC cable. Any ideas about how to go about fixing this? I have a sinking feeling that this may have been a manufacturing defect in the product, since this issue has existed since day one. (FYI: I have an extended repair warranty on this product).
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 6 Answers
This problem can be caused by mainly two different things. It is either the AC Adapter itself and has a short in it, or sometimes it is caused by the Power Jack inside the laptop. Are you familiar with how to read a voltmeter? I can walk you through testing your adapter. If it is either issue, I would recommend trying to fix through warranty if possible, because the power jack repair can be expensive. If you need to replace the AC adapter, I recommend a genuine adapter, as universal adapters and cheap knockoff brands will cause issues with your laptop and usually not last very long.
Posted on Dec 11, 2009
SOURCE:
Audio codec for gateway M6843
K-Lite is the best and most powerful codec packs out there. Not to mention free.
Oct 01, 2012 | Gateway M-6843 Notebook
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
Hp compaq nc6320 doesnt charge
i thibk the charger head went out thats what happend to my gateway just cut the part of the charger that goes into the computer (if its not the prob u can fix it back later) cut it open and see if any of the wire has broke off if so use a soutering iron (i dont know how to sourtering)
and some souter and souter it back on thats the best i can help
ps i done this to my gateway labtop and it worked fine
Oct 02, 2009 | HP Compaq nc6320 Notebook
Gateway laptop AC adapter not working
Fixable? Maybe
Sounds like a problem with the power jack on the Motherboard. If so, it is possible to remove the board and replace the jack but this requires soldering skills and is probably not something the average person would want to try.
You might try another adapter to be sure but if it is a motherboard problem the best solution is probably to junk it and buy a new laptop.
Mar 14, 2009 | Gateway 450ROG Notebook
I need to buy a power adapter for Compaq C504EA notebook.It is only 18 months old and this is the 3rd time the charger needs replacing
hi
Your best bet would be to have a look on ebay for the charger. i've posted a link. just look around a bit you will find a lot more.
As for the ac adapter frying.. looks like you have some voltage issues. use the adapter with a powerguard or power stabilizer.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=250282392936&Category=31511
hope this helps
cheers
kbh
Oct 08, 2008 | Compaq Computers & Internet
The AC adapter that I brought from Best Buy doesn't have enough power to get my computer to- charger-up. The S/N of my computer is T3A6931000974. The tec from best buy said that the adapter didnt have...
Looks like a 90 watt AC adapter will do what you need
http://www.batteryfuel.com/ac-5001sp-gateway-mx6955-laptops-90w-universal-notebook-ac-adapter.html
Sep 05, 2008 | Gateway Computers & Internet
Notebook power adapter
hi
I am a Dell Certified Sysyem Engnieer(DCSE).
the issue you are facing with the system seems either for ac adapter or to the port you connect the ac adapter to
now if you already tried a good known ac adapter on your system and it does the same thing
wot i can suggest is get a new ac adapter as it would be less expensive otherwise the system board needs to be replaced.
My honest advice would be get a Dell next time whenever you purchase a computer.you will get great technical support over the phone and chat.
Jun 10, 2008 | Acer Computers & Internet
Gateway laptop not working
What is the problem with the notebook?
Do you get any lights on the notebook when its plugged in?
Have you tried another power adapter?
Dec 26, 2007 | Computers & Internet
Gateway M-6843 Notebook Logo
308 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
